Postby mikeschn » Sat Dec 31, 2011 9:34 am
Just a quick diversion, have you guys seen this canvas covered teardrop already?
http://www.nicksteardrop.com/canvas.htm
Postby eaglesdare » Sat Dec 31, 2011 9:47 am
i haven't seen that one yet, but it looks like a nice td.
Louella
May the foam be with you.
eaglesdare
Postby GPW » Sat Dec 31, 2011 10:16 am
Seeing that , thinking I could have eliminated a lot of roof problems on my original Plywood TD by canvas covering the ply roof ... That would have been so easy and eliminated the splitting/checking on the roof that happened so quickly ... Just hindsight ... FWIW :roll:
The Old Timers knew what they were doing ... ;) That’s a Nice looking TD Mike ... very “Old Schoolâ€
Postby linuxmanxxx » Sat Dec 31, 2011 1:11 pm
Mike and distinguished cohorts :lol:
I followed the other thread and was digging around at the armorstone site and found they have tons of different epoxies for protection of zoo/museum displays and other things and this line of flexible epoxies looks very promising but I bet the pricing is high.
http://www.polygem.com/zoo/flexct.php
linuxmanxxx
Images: 10
RE: HWFF Reply
Postby mezmo » Sat Dec 31, 2011 11:46 pm
Hi fellow Foamlings and Foamanistas,
I received a reply from the Hot Wire Foam Factory Customer Service:
Here It is:
From: david <[email protected]> [Add to Address Book]
To: [My Email -Norm/mezmo]
Subject: Re: Hot Wire Foam Factory: Best Foam Encapsulant
Date: Dec 31, 2011 5:51 PM
Hi Norman,
I checked out your site- you guys are really creative. I think that our Styroplast will be the best choice for TTT's. It is super tough, light, waterproof, weather resistant, and is easily brushable so no spray equipment is required. Although you can use a mesh (which we also carry) to make it super strong, it is nearly as strong as resin and fiberglass all on its own, it's stronger than epoxy. You have to paint or at least primer it right away to get the best paint bond. Otherwise you have to use an expensive epoxy primer on it after it dries. It is used for coating props and backdrops in amusement parks where it's got to hold up to lots of abuse. Truly an amazing encapsulant.
Here's a link to a bunch more information on Styroplast:
http://hotwirefoamfactory.com/-024-GAL- ... allon.html
If you or another active member wants to do a review we can send you samples at discount prices.
How are you guys cutting the foam now?
Best regards,
Dave
The problem with the Styroplast is it is a bit pricey, but then again, it may
be in the same ballpark as an epoxy coating? I don't know as I haven't done
a comparison of the two. If someone has experience with epoxy coating
costs, then please chime in on this. The Styroplast is $85 per gallon. The
above link from HWFF has the coverage info.
Here's a corresponding link for their Foam Coat product:
http://hotwirefoamfactory.com/-025Bulk- ... 25lbs.html
This is much cheaper - @$29.95 per 25# box, and would probably need
their "Boost" fortifier additive @ $27.94 per 32oz or the "Bounce"
rubberizer additive @ $19.95 per 32oz depending if you want a real hard
top coating or one that's flexible.
The final cost determination would be how thick one wants the final
coating to be. Since these coatings are either a light tan or light grey
they'd need to be painted anyway so that'd probably take care of any UV
concerns.
Just wanted to pass this along. It'll be interesting to see Mel's test strip
results once he gets them done.
The reason I've been pursuing this is I was wondering if these coatings
would be longer lasting or more durable than the TBII&III glues and
paints as it has been mentioned that those are sometimes thermally
affected. And then there's the bedliner type materials as well to think
about in this area too. Costs and weights also enter into the picture when
trying to decide the best choice here as well. So just gather all the info
we can, evaluate for your situation, make your choice, and go on from
there, would seem to be the path to pursue.
Cheers,
Norm/mezmo
mezmo
Images: 194
Postby Wolffarmer » Sun Jan 01, 2012 2:16 am
Neato Bandito
or something like that
Randy
Wolffarmer
Images: 309
Postby eaglesdare » Sun Jan 01, 2012 6:56 am
as you all know already, i am not a technical person, so please bear with this question: (did i use the right bear? thats not the question though)
if one uses this stuff nezmo speaks of, do you still cover in canvas? or is this stuff put straight on the foam and your done?
Louella
eaglesdare
Postby GPW » Sun Jan 01, 2012 7:32 am
Bear ..... Big fuzzy trailer destroyers...
Bare ..... Naked ...
Behr .... Paint Company
Barre ... Rosanne !!!
:lol:
Eagle , I just can’t rest till you iron those bubbles ... which BTW I don’t think those are “thermal affected “ , but more cinch strap affected ... It’s going to take a lot of convincing to get me off the idea of canvas and paint ... which has been Proven over many years and still remains (AFAIK) the Thrifty alternative...
:thinking:
Postby eaglesdare » Sun Jan 01, 2012 8:25 am
i think i am with you glenn, on the reason this happened. i really do think those cinch straps (at the least) have helped this to happen.
i know how it affects my doors and locks. but the cold weather could be helping that issue.
please don't hold your breath waiting for me to go out to iron. my hubby did not marry me because of my domestic goddess abilities. now i can bake and make a cupcake, cookie, leg of lamb, but hell i don't even know where the iron is. do we even have one of them? :lol: seriously, i will fuse with that in the spring time. or at least when it is much warmer out there.
right now, all i can think about is getting the next trailer ordered. i will be doing my taxes here shortly, get that refund, and order the trailer. then i will start serioulsy planning my next trailer. i might even go with that stuff that nezmo is referring to. i am going to read more about it, and i will probably get in touch with that guy also and chat with him.
Louella
eaglesdare
Postby GPW » Sun Jan 01, 2012 8:56 am
The next trailer ... Oh Yeah !!! The same thing also incessantly occupies my thoughts and dreams ... :thinking: I’m “hookedâ€
Postby eaglesdare » Sun Jan 01, 2012 9:01 am
nope no ironing here from this ole gal. LOL if i forget to get the clothes out of the dryer right away, i just rewash and redry. if it has to get ironed , it gets thrown away. :roll:
Louella
eaglesdare
Postby GPW » Sun Jan 01, 2012 9:17 am
Well, in that case, sorry I even mentioned it :oops: I just thought it’d be a quick fix for the “Bubble Bluesâ€
Postby eaglesdare » Sun Jan 01, 2012 9:21 am
ah i see your issues. i won't make any promises, but i will look for an iron then. if i actually find one, i will attempt this. how's that. :lol:
Louella
eaglesdare
Postby GPW » Sun Jan 01, 2012 10:11 am
Just thinking about the future .... Since Foamies will likely suffer some road damage , bird strikes, frozen turkeys, idiots with hammers, Bears (Oh my ! ) ... it’s good we discuss the repair aspect ... which on a foamie should be pretty Simple and quick to do ... weather permitting of course ... ;)
Please don’t go outta’ the way to do this , but if you happen to pass by the trailer with a hot iron in your hand :roll: , you might want to give it a go ... just to see if it works ... :thumbsup:
Ps. I did iron the seams on my Foamie during construction, just to flatten the edges ... that worked well and “fusedâ€
Postby GPW » Sun Jan 01, 2012 11:29 am
... here’s my version of an “on the roadâ€
