Door Frame Question
Door Frame Question
Postby ukuleleblues » Sat Jan 07, 2012 10:45 am
I am going to frame my doors with 3/4 in spruce the same thickness as ther walls.. The walls are 1/2 ACX with 1 inch x 1 inch studs with a 1/8 birch inside skin. The jamb and hinge area of the door will be backed with 1" thick x 1 in wide studs. See pic.
Any suggestions such as wood type or if my design seems OK?
http://dl.dropbox.com/u/583093/doorframe%202.jpg
ukuleleblues
Postby aggie79 » Sat Jan 07, 2012 2:15 pm
If you haven't already, you should consider what type of door hardware - hinges, latches, door stops, windows, etc. - to make sure you have framing in the right places for these.
Postby bdosborn » Sat Jan 07, 2012 2:45 pm
That's how I did mine. One trick is to brace your door to fit the frame until you skin it. I've done 4 doors on 2 builds and the door and opening never came out quite square. The brace made sure the frame had the same crookedness as the opening. :lol:
Images: 806
Postby ukuleleblues » Sun Jan 08, 2012 8:10 am
Thanks for the info and advice.
Do you all think Spruce would be a good choice for the door frame? Any better wood choices for this application.
Does anyone use a standard door knob?
ukuleleblues
Postby bdosborn » Sun Jan 08, 2012 9:30 am
I think it depends on where you live on what kind of wood to use. Spruce isn't readily available in Colorado so I used poplar. Its cheap here and it holds a screw well. I've never used spruce but I know other list members have to good results.
I like the hardware Grant at Lil' Bear carries:
Door Handle Link
Images: 806
