Hi everyone!
Been lurking here for a while (did post once or twice a while back but anyway) and have been contemplating the notion of a teardrop.
For reference sake we have two vehicles in the household. Mine is a 2003 Pontiac Vibe. The other is a 2004 Ford Escape, 2wd with a 6 cyl which is accessible to me but not mine.
Both have hitches.
2 summers ago I bought a 1968 Red Dale trailer. 14'. Did a little work on it to make it campable. Weighed in at around 1800 pounds so, naturally, towing it with the Vibe was out.
I added an engine oil cooler to the Escape. First trip out took it to Erie and ended up blowing the seal in the cooler on the way back. Disastrous trip that I won't bore anybody on the details with. But, the long and the short of it is that I started thinking it might be better to consider something a tad lighter. Something that is capable of possibly being towed by both vehicles.
The tow capacity of the Vibe is around 1000 pounds. The tow capacity of the Escape, with out any kind of oil cooler is around 2000 pounds. At least, from all I've read, anyway.
I've towed a small trailer with a 500 pound motorcycle on it behind the Vibe with no issues. So, I figure a lighter teardrop should be doable.
So, I'd like to ask a couple of questions, possibly of somebody else from PA who has had to deal with PennDot.
In the course of dealing with titling issues for the Red Dale, I've learned what it takes to get a HF trailer licensed for road use in this state.
It requires taking it in for a special inspection, then taking all the necessary forms to a notary for processing. Not a HUGE issue but a nuisance and an expense, none the less.
I had thought about perhaps building one of the ultralight models described in the design library. Perhaps a Superleggera or even the PICO.
My question is about the legality of a simple A-Frame type setup here in PA.
A HF frame I can build, get it certified and then build the trailer on top of it. So long as it comes in under 2000 pounds and the axle rating remains below that no further inspections or titling would need to be necessary, so far as I can tell.
I'm wondering, with how strict PA is about nearly everything PennDot, if a simple A-Frame would ever meet their inspection requirements.
Has anybody built one here?
Just trying to assess my options up front.
Thanks
TJ
