Jeep tiny camping trailer
Postby steveyos » Sun Jan 15, 2012 11:58 pm
Hi everyone here is my build.
I wanted a light weight trailer to pull with my Jeep Wrangler. I had a small tent trailer but when camping in some areas, like the desert when it is windy did not work well. The tent trailer was also a hassle to set up.
I stated with a 4x7 trailer from Tractor Supply ($599.00) I removed the back ramp but left the sides for bracing. The bottom of the trailer was covered with a plastic board then the floor was built with 2x2s and insulated with 1 ½ foam board.
The walls were constructed with 1/8 inch hardboard panel on the inside and White FRP board on the outside. In the middle is 3/4" x 4' x 8' Polyisocyanurate Insulated Sheathing making a sandwich which was glued together with a 1x3 around the edge.
The roof was constructed in a similar manner.
The rear galley door, window and door were all purchased on eBay.
I used a lot of Gorilla glue and calking so it was usually on my hands when I should have taken pictures but did not want to get it on my camera.
I took it on it's first trip this weekend and it pulled very well with the Jeep.
I still have some trim to complete on the inside along with some wiring. I also need to get a memory foam pad.
The only problem I saw on the trip was even though it is well insulated (R-5) I did have a condensation issue. I read about the CO2 issues so I installed a detector and am not using any heater. I was in the 20's where I camped so I did not leave a window cracked open and I was a little cooler than I would have liked. Is condensation normal? any thoughts?
Tulare, California
steveyos
Images: 15
Postby Facemeltingly Epic » Mon Jan 16, 2012 12:30 am
Nice work. How long did it take you to build?
I made extensive use of Gorilla Glue on my build as well. I dealt with the glue-on-the-hands problem by wearing nitrile gloves any time I was gluing something.
I'm afraid I don't have an answer on your condensation question...
Scot
My build journal: http://www.tnttt.com/viewtopic.php?t=42585
Not enough photos there? Try here:
http://www.facebook.com/media/set/?set= ... c3e73ca184
Or here:
http://www.facebook.com/media/set/?set= ... cf567dd7b7
"Politicians are like diapers. They should be changed often, and for the same reason." - Mark Twain
Facemeltingly Epic
Postby steveyos » Mon Jan 16, 2012 12:37 am
I started December 17th 2011 and the first trip was Jan 12th I worked on the weekends and after work.
Tulare, California
steveyos
Images: 15
Postby Facemeltingly Epic » Mon Jan 16, 2012 12:52 am
Awesome. And people thought I was going quick on my build because I had it camp-ready in a month and a half...
Scot
Or here:
Facemeltingly Epic
Re: Jeep tiny camping trailer
Postby bonnie » Mon Jan 16, 2012 9:13 am
steveyos wrote:The only problem I saw on the trip was even though it is well insulated (R-5) I did have a condensation issue. I read about the CO2 issues so I installed a detector and am not using any heater. I was in the 20's where I camped so I did not leave a window cracked open and I was a little cooler than I would have liked. Is condensation normal? any thoughts?
Hi,
You need to have some ventilation to reduce/eliminate the condensation. Cracking the window, even a tiny amount would help. I bought a solar vent for my future build, so that it will work even when I'm not using the TD/TTT.
Very nice looking camper.
Bonnie
Remember, the turtle won. :)
bonnie
Images: 107
Postby Blotto Bros » Mon Jan 16, 2012 6:53 pm
how much room did you leave for "foot space" under your galley? Will there be enough once you put in a mattress?
Even those souls that are found must occasionally become lost to appreciate what they have.
Blotto Bros
Images: 51
Postby bam1029 » Mon Jan 16, 2012 9:15 pm
I like the rear doors. Where are they listed on eBay? Nice project. I especially like what you are pulling it with.
bam1029
Postby Martiangod » Mon Jan 16, 2012 9:37 pm
Condensation is a good/bad thing, it means you have it rather tight as far as air leakage, thats a good thing, won't be drafty, crackin a window or vent will alivieate the condensation
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby steveyos » Mon Jan 16, 2012 11:17 pm
Blotto Bros wrote:how much room did you leave for "foot space" under your galley? Will there be enough once you put in a mattress?
I have 12" and plan on using a 4" memory foam pad.
Tulare, California
steveyos
Images: 15
Postby steveyos » Wed Jan 18, 2012 6:35 pm
bam1029 wrote:I like the rear doors. Where are they listed on eBay? Nice project. I especially like what you are pulling it with.
I got the rear doors and the window from seller bottomdollarsurplusinc on ebay. You should be able to search eBay for him. He has lots of items, low prices and fast shipping.
Tulare, California
steveyos
Images: 15
Postby jss06 » Wed Jan 18, 2012 9:37 pm
I got my windows at the same place. Great people to do business with.
jss06
Palladium Donating Member
Postby steveyos » Wed Jan 18, 2012 10:55 pm
bam1029 wrote:I especially like what you are pulling it with.
Here is a pic of the tow vehicle
Tulare, California
steveyos
Images: 15
Postby Zboom » Thu Jan 19, 2012 2:03 am
Nice YJ! Square vs round, lol...
Zboom
Images: 32
Postby steveyos » Sun Feb 12, 2012 12:54 am
Camping this past week at King of the Hammers in Johnson Valley (Hammertown USA)
Tulare, California
steveyos
Images: 15
Postby steveyos » Mon Mar 26, 2012 11:44 pm
Went to Oceano two weekends ago it rained alot but I was so comfortable in my little trailer. Love it.
Tulare, California
steveyos
Images: 15
