PaulC wrote:Sounds to me like you've reverse earthed one of your taillights. I'm thinking one light has earth to earth but the other has positive to earth. This would enable a completed, low voltage circuit to happen. It sounds like and earth leak thing so check all your earth points. It also sounds as though it is only low voltage leakage.
Cheers
Paul
eamarquardt wrote:PaulC wrote:Sounds to me like you've reverse earthed one of your taillights. I'm thinking one light has earth to earth but the other has positive to earth. This would enable a completed, low voltage circuit to happen. It sounds like and earth leak thing so check all your earth points. It also sounds as though it is only low voltage leakage.
Cheers
Paul
What exactly is a "reverse earthed" taillight?
Gus
Cheers
Paul
