jdarkoregon wrote:Becky,
Everybody learns differently, good for you if classes work for you.
The suggestions given above are pretty darn good, in fact great. I learn by tinkering, so here's another suggestion.
Get a battery, something small that doesn't scare you, maybe one of those squareish 9 volts, you know the ones in the smoke detectors.
On a table, connect a small light bulb (flashlight size or maybe a DC fixture you have already purchased)
Wear some rubber gloves, and tinker, Maybe go to radio shack and get some wires with clips on the ends, so you can clip the ends to things like battery terminals, wires from fixtures, or switches
Have fun learning, no matter how you do it,
John
Oldragbaggers wrote:Lots of great replies and information here. You guys never fail to come through!! Thanks to all, and also for all the helpful pm's I received.
(Sharon, I am currently reading 12V Bible for Boats, but I plan on ordering the book you suggested. Thank you.)
jstrubberg wrote:jdarkoregon wrote:Becky,
John
This is a fantastic suggestion. A 9 volt battery, some wire and alligator clips and a couple of LED bulbs and you could set up and tear apart circuits with zero chance of hurting yourself. Hands on is a great way to learn.
angib wrote:I believe the most important thing to learn about wiring is that electricity is just compressed smoke - which explains why, when anything goes wrong, smoke comes out.
Starting with good quality smoke is the basis of proper electrical work and I recommend the following, as produced by the Prince of Darkness himself (Joseph Lucas):
