... and now , about those air conditioners...
Postby swampjeep » Wed Jan 18, 2012 9:50 am
I'm guessing that is a 110v unit? what amp breaker is required to run it?
swampjeep
Postby linuxmanxxx » Wed Jan 18, 2012 2:02 pm
swampjeep wrote:I'm guessing that is a 110v unit? what amp breaker is required to run it?
Yes it only requires 1200 watts for startup so it would run on a 10 amp circuit just fine but according to ul specs all ac units are to be on their own 15amp circuits and yes they are 110v.
linuxmanxxx
Images: 10
Postby Shadow Catcher » Wed Jan 18, 2012 6:59 pm
This a more powerful version of the Pet Cool and the heat is resistance heat not a heat pump where the compressor reverses. VERY expensive, about three times what I spent total.
Postby linuxmanxxx » Wed Jan 18, 2012 7:31 pm
For you Spec lovers out there (note it has the new freon about to become the new standard soon):
Name / Model # Climate Right Max / CR-7000
UPC Code 021251070000
SRP $599.00
Internet M.A.P. $579.00
Recommended Applications Work sheds, cabins, job site trailers, extra large pet duplexes, and more
Cooling Capacity 7000 btu
Heating Capacity 7500 btu
Dehumidifying Capacity 60% RH 0.20 gallon/hr
Power 115v/1hp/60Hz
Current 7.7a
Input power at startup 0.84kW
Room Coverage * 350 - 1,200 cu feet
Compressor Manufacturer Toshiba
Thermostat Digitial Display. Set to 61-87
Control Panel Digital. See Operating Manual
Unit Dimensions 20" L x 16.5 W x 14" H
Case Dimension (1 ea) 27" L x 19" W x 16" H
Hose Dimension
(2 hoses) 4.7" in Diameter, 39" L
Hole Saw Dimension
(1 pc) 4.5" in Diameter, 1.6" L
Couplers Dimension
(2 pcs) 4.5" in Diameter, 2" L
Clamps Dimension
(2 pcs) 4.7" in Diameter
Mesh Filter Dimension
(1 pc) 3" x 3"
Screws Dimension
(8 pcs) 0.16" x 0.32"
Foot
(4 pcs)
Drain Mouth
(1 pc) 0.16" in Diameter, 1.6" L
Weight 60 lb / 63 lb case
Hookup system Dual (2) Hose System (air intake/air outflow). Unit sits outside of enclosure. Accessory/Hookup Kit. Caster wheels
Assembly Kit ** Customized for wooden structures
Refrigerant R410a (New Regulatory compliant)
Air Filter Nylon Net
Noise 56db
Drain Pan included? No
Recommended Generator 1500W min (~900W est startup)
Replacement Parts? Yes. Coming Fall 2011
Color Off White
Operating Manual Included in box
Warranty 1 Year Limited Warranty
Technical Support/Troubleshooting 800-7-CLIMATE opt. 2
Outside lowest temperature 5 Degrees F
Outside highest temperature 109 Degrees FName / Model # Climate Right Max /
linuxmanxxx
Images: 10
Postby GPW » Thu Jan 19, 2012 6:20 pm
That does look like a Very Nice unit for somebody with the Fun Tickets ... 8)
Postby linuxmanxxx » Fri Jan 20, 2012 1:55 pm
Well another advantage is you just put ports in multiple things and use the one unit in a shed, shop, room, and camping.....can multipurpose and the hose thing is way easier than mounting window units. If you look in the last build of my microcampers you see the window unit builtin and just building that shelf where it leaned to a drain waterproofing and then closing in took 4 days of work and this unit takes cutting 2 holes so the time saved building is worth the higher price trust me. That was the 2nd unit I built in and buddy it just blows chunks the amount of work it entails.
linuxmanxxx
Images: 10
Postby Shadow Catcher » Fri Jan 20, 2012 5:56 pm
I can say first hand that yes there are some advantages to being able to add ports in other locations, but there is an efficiency cost unless you insulate the hoses and make sure there is sufficient air flow. I tried that with our pet cool using closed cell neoprene pipe insulation but it did not make up for the lack of coolth from the original PC.
Postby linuxmanxxx » Fri Jan 20, 2012 6:14 pm
Yeah that's why unless it's a very small area no way I'd recommend to get the 2500 as that's half of the smallest window unit and just way undercooling.
linuxmanxxx
Images: 10
Postby linuxmanxxx » Fri Jan 20, 2012 6:19 pm
linuxmanxxx
Images: 10
Postby linuxmanxxx » Fri Jan 20, 2012 6:22 pm
Yeah why I'd never ever recommend the 2500 to anyone unless they were going to cool and heat a shoebox just way too small. Smallest window unit is 5k btu and it would cool my cabin real well but throwing the door open to the tent put a strain on it for sure.
linuxmanxxx
Images: 10
Postby GPW » Fri Jan 20, 2012 8:40 pm
Being an old retired guy and all , I was thinking about something in the neighborhood of $100.00 (read: Cheap Ba****d) :o ....and around 40 lbs. ... :thinking:
Postby linuxmanxxx » Fri Jan 20, 2012 9:02 pm
GPW wrote:Being an old retired guy and all , I was thinking about something in the neighborhood of $100.00 (read: Cheap Ba****d) :o ....and around 40 lbs. ... :thinking:
Well don't have the 100 or the 40 lol it's 60 and comes with a storage case and is on wheels and don't forget that pimping control panel lol.
linuxmanxxx
Images: 10
