Found MDVaden's site on the web, and another on ADVrider, which led me to here and the rest is history. You folks are sheer mad genius. (takes one to know one I suppose)
Started with a trailer big enough to haul the 15'-8" canoe if needed. then decided if everyone and everything else would fit. Wanted to keep everything bare bones, functional, and modular.
Found some surplus military cots, used some leftover kayak straps, ordered e-track fittings, insulated roof, walls, and corners, waiting to install the Fantastic Vent (fan) when the weather improves.
Thanks (and blame) to most everyone here. Been to busy working on it and now enjoying it to post anything.
Started with a 7x16 Cargo Craft Expedition.
Had the factory install straight axles for extra clearance, RV door, and two windows offset (thanks "Gonefishin").
Added a 15 amp circuit, with a WFCO converter and a few GFCI outlets.
Preferred barn doors over ramp for our use.
Used 1" foam insulation and armorflex wire, (boy am I cheap) taped the seams, off we go.
Here's our led rope lights for camera light, can't remember who here donated that idea, but it is great.
Test loaded the trailer, getting pretty busy in there.
Forgot to mention we used vertical E-track to mount everything, even to help hang the cots from the ceiling.
Here we are setting up camp on the first trip.
Our first trip, boondocking, breakfast is served!
Trailer manufacturer had no extra charge for color, of course I tried to match the tow vehicle.
Thanks again to everyone here for the ideas, and encouragement. I looked at all types of RVs, new and used, but nothing seemed to work for us. Most everyone had a recommendation other than what met our needs. So when they said No David! I guess I did it anyway.
