Hot Wire Foam Cutting ....
Postby GPW » Wed Jan 25, 2012 7:45 pm
... and the wife just agreed with the both of us ... :o Mum's the word !!! :shhh:
Postby allan1 » Sat Jan 28, 2012 10:36 pm
mikeschn wrote:I'd like to see a picture of a hot wire cutter in action...
Got any pics?
Glenn, you are going to have to design us a roundover wire cutter that runs on 4 D sized batteries... ;)
Mike, heres some links to more battery operated cutters.
http://www.instructables.com/id/Hot-Wir ... y-Powered/
http://www.google.ca/imgres?q=battery+p ... mBw&zoom=1
http://www.wantitall.co.za/Toys/Crafter ... B004E97LCI
http://www.flyelectric.ukgateway.net/hotwire1b.htm
Have seen some pics of people using plug in power adapters and I think I'll go the the local 2nd hand store and pick up a couple of different types and experiment.
allan1
Images: 19
Postby eaglesdare » Sun Jan 29, 2012 7:43 am
oh no, does this mean i have to watch allan also? :lol:
i do like that cut though, nice :thumbsup:
Louella
May the foam be with you.
eaglesdare
Postby mikeschn » Sun Jan 29, 2012 8:10 am
Do you have any examples of wire cutters that can cut a roundover?
Mike....
Postby Larry C » Sun Jan 29, 2012 10:25 am
mikeschn wrote:Do you have any examples of wire cutters that can cut a roundover?
Mike....
I would like to see that also. It seems the only way it would work is with a piece of thin stiff flat material. It would keep it's curved shape, and wouldn't bend like round wire especially on a large radius.
We have these at work (see link). I think this would be stiff enough for a roundover cut, but I don't know how much current would be required to heat it enough. These are 1/4" wide, but it looks like there is also a .177" width. They are very thin, and would cut like a knife .015" thick.
It could be formed to shape similar to the Ohms Symbol, but with the legs further apart formed to the desired radius.
http://www.band-it-idex.com/en/products/Stainless_Steel_Ties/Tie-Lok%20Ties.html
"If its worth doing it's worth doing Light"
http://www.tnttt.com/viewtopic.php?f=50&t=35852
Larry C
Images: 78
Postby allan1 » Sun Jan 29, 2012 6:53 pm
Mike....
This should do the trick simply (found on internet).
allan1
Images: 19
Postby mikeschn » Sun Jan 29, 2012 9:14 pm
Mike....
That looks good. Tell me where I can get that wire... and of course, please tell me what kind of wire that is...
MIke...
Postby allan1 » Sun Jan 29, 2012 9:36 pm
mikeschn wrote:
Mike....
MIke...
Mike both excellent questions and all I have for you are silly answers. I've only started to learn about hot wire cutters in the past week and so my humble self pleads ignorance. GPW, pete42 or Larry C would be a better source of opinion at this point. At this point in my learning I'd just grab whatever wire I had hanging around and try it.
allan1
Images: 19
Postby GuitarPhotog » Sun Jan 29, 2012 10:54 pm
GuitarPhotog
Images: 55
Postby GPW » Mon Jan 30, 2012 6:59 am
Postby GPW » Mon Jan 30, 2012 7:16 am
Here’s another take on a quickie HW foam cutter ... http://www.rcgroups.com/forums/showthread.php?t=1244763
BTW, lots of HW cutting info on this site .... use the search function ...
Postby allan1 » Tue Jan 31, 2012 12:40 pm
GPW thanks for the link. Bought a power supply on ebay and it's on its way! Found my beginners website - uncomplicated info about power supplies, tool plans, wires, good video links, etc. Time to start building a table and tools.
http://hotwirefoamcutterinfo.com/Hot_Wi ... ction.html
allan1
Images: 19
Postby GPW » Tue Jan 31, 2012 1:01 pm
Lots of good info out there , one only has to search for it ... :thumbsup:
Postby allan1 » Fri Feb 03, 2012 2:33 pm
just came in the mail ... TEC 3 Power Command 9000. Output is 20Vdc, 19VAC, 20VDC - all no load ratings. I'll have to find out what that all means. And it's got dials, switches and meters .... ohhhhhhh
allan1
Images: 19
Postby GPW » Fri Feb 03, 2012 3:19 pm
Looks Cool ... dial in the Heat ... :thumbsup:
