by eamarquardt » Thu Feb 02, 2012 2:45 pm
As I recall trailers tow a bit better if there is some toe in. I've never checked any axles I've installed and haven't noted any markings.
Take a couple of straight edges and clamp em to the hub (center them) and then measure the distance from one end to the other both front and back. If there is a difference mount the axle with the short distance forward. If the straight edges are about the same length as the diameter of you wheel, I'd look for about 1/8" difference. If it's a lot more I'd say the axle might be "suspect" and I call an axle manufacturer and ask em what the "deal" is.
Hope this helps.
Cheers,
Gus
