Hi All!
I am building on a 5x8 ft Red Trailer frame.
The axle is not standard but came as an option from Red Trailer.
It is much heavier and accommodates a 13 inch wheel and 10 inch brakes.
(I choose it becuase I wanted brakes.)
It only installs in one direction because the axle is round in cross section and it has mounting plates welded on for mounting to the springs.
Once mounted the curve (bend) of the axle, which is obvious no straight edge needed, is downward.
The only way to have the curve upwards is to mount the axle on top of the springs, but in this design the thickness of the axle cross section would not permit this.
Do any axles have the curve downwards?
So far my research here suggests not.
I can post a pic later if the would help.
