Question, the 1and 1/2 inch vent pipe must go through the roof of the cargo trailer, Please tell me how
you dealt with this? Did you back up the thin metal roof with something, and how did you seal the hole?
Thanks
Johnnie
closurdo wrote:All you need is the plumbing vent cap kit http://www.campingworld.com/shopping/item/replace-all-plumbing-vent-kit-polar-white/35181 secured correctly to the roof.
The hole around the pipe itself can be a little larger that the vent pipe because the design of the vent cap keeps it from leaking. As stated in the above post the vent pipe should protrude through the roof by about 2". If you have a small mom and pop rv/camp store in your area you may be able to find a metal vent pipe cap kit instead of the plastic one that campingworld sells.
