Shadow Catcher wrote:The inverter is supposed to be here here Thursday. I had thought of using a UPS and actually bought one, not the best experience with it and not enough power.
Progressive Dynamics has a transfer switch that I will probably order and this has a couple of relays and a time delay so there is no chance that AC will back feed through the inverter, reportedly sparks fly and smoke is released, and as we all know getting that smoke back in where it is supposed to be is a pain. I suppose I just have to figure out which wires to intercept in the power center.
Sounds like you are trying to avoid "smoke testing".
Wikipedia: In electronics and electrical engineering the term smoke test or power on test is used to refer to the first time a circuit under development is attached to power, which will sometimes produce actual smoke if a design or wiring mistake has been made. Most often this smoke comes from burning resistors, which produce a unique smell familiar to many technicians. For certain circuits, overheating and burning due to circuitry that is still not properly operating can be avoided by slowly turning up the input voltage to the unit under test by using a variable autotransformer and watching the electric current consumption[citation needed]. As a poor-man's "autotransformer", a properly-sized incandescent light bulb in series with the power feed can provide a similar benefit: if the unit under test has a short circuit or other overload, the bulb will light up and provide a high resistance, limiting or preventing further damage to the unit being tested.
Overloaded integrated circuits typically produce "blue smoke" (or magic smoke). "Blue smoke" is the subject of jokes among technicians who refer to it as if it were a genie in the circuit: It's the blue smoke that makes it workâlet out the blue smoke and it won't do anything.
Cheers,
Gus
