MushCreek wrote:I would say the loaded trailer is around 2500-3000 lbs. The axle, springs, hubs, and tires are rated for 3500. I can pick up 200 lbs. without too much trouble, and I couldn't budge the tongue- I can barely drag it sideways. The load was pretty well balanced side-to-side. As I said originally, light tongue weight doesn't seem to be the problem. The trailer is still fully loaded at my place in SC. I'll be back there in April, at which time I'll do some more investigating. Yes, the tires are bias play-as are all of the other trailers I tow successfully.
Another cause of sway apart from low tongue weight is big inertia - if you have heavy weights at the front and back of the trailer you can still achieve a reasonable tongue weight but the 'dumb-bell' weight distribution increases the likelihood of sway - or, more accurately, reduces the speed at which sway will start.
48Rob wrote:
If a trailer weighs say, 3000 pounds, and you have 12% (360 pounds) tongue weight, but you have 500 pounds behind the axle and 2500 pounds forward of the axle, does this constitute "dumb-bell" weight distribution?
(Since the axle placement is being kept rearward to allow for pleasingly aesthetic door location, weight is added to the rear to keep tongue weight from becoming too great)
The axle placement would also dictate to a large degree the overall balance, no?
At what point would the design start to suffer, when the weights fore and aft are similar, even if the axle is well back and if so, wouldn't you be forewarned by the loss of appropriate tongue weight?
I'm not arguing, but I am trying to learn, as I am in the midst of a design...![]()
Rob
