Rockwood Popup
Rockwood Popup
Postby MikeyLikesIt » Mon Feb 20, 2012 10:53 am
We got a Rockwood Popup camper for $60. It took 3 and a 1/2 men and a few beers to strip it down, but it looks like it has a solid frame and very little surface rust.
Has anyone used one of these before?
At the widest it's 6'1". It's on a 4' torsion axle.
I would like to have a 5' wide teardrop. Any suggestions on modifications?
I would also like it to ride higher. Is the angle on the axle difficult to change?
Thanks,
Mikey
MikeyLikesIt
Re: Rockwood Popup
Postby angib » Mon Feb 20, 2012 1:24 pm
MikeyLikesIt wrote:I would like to have a 5' wide teardrop. Any suggestions on modifications?
You made a good choice as it looks like the 'outrigger' parts of your frame can be cut off leaving just the inner frame. That may be less than 5' wide but you can build the body wider than the frame -though you still need it to fit between the wheels.
MikeyLikesIt wrote:I would also like it to ride higher. Is the angle on the axle difficult to change?
Is impossible difficult enough for ya? The angle can't be changed so to ride higher you carefully cut the axle off the frame, weld in a spacer (rectangular tube is best) of the right height and weld the axle back on.
It would be sensible to check the axle is in good condition before doing much work. If you stand on the frame at one end of the axle and jump, does the suspension move a decent amount? If there is no/little movement (say, less than half an inch) the rubber in the axle is shot and the simplest/cheapest cure is to replace the axle - repair is not possible.
angib
5000 Club
5000 Club
Images: 231
Re: Rockwood Popup
Postby aggie79 » Mon Feb 20, 2012 3:53 pm
If the axle is still good, you may be able to find some larger wheels and tires that fit the bolt circle of your axles' hubs. This might be easier than adding a spacer to the axle.
Re: Rockwood Popup
Postby MikeyLikesIt » Mon Feb 20, 2012 4:02 pm
I did the bouncy test and the axle does have a good flex.
I plan on some larger wheels. I think the ones on it are only 8".
MikeyLikesIt
Re: Rockwood Popup
Postby fromeo » Tue Feb 21, 2012 10:17 am
I built on a Rockwood frame, very similar to that one. Like Andrew said, the outriggers are easy to remove/modify, so altering the width is not difficult as long as the wheels where you need them width wise. Also as mentioned above, the axles are not adjustable, so I added an additional 2" of steel spacer to allow for bigger wheels/tires. Some pics on page 1 of my build thread: http://www.tnttt.com/viewtopic.php?f=50&t=37391.
- Frank
fromeo
Re: Rockwood Popup
Postby Laredo » Wed Feb 22, 2012 12:47 am
If you go to Popupexplorer, you will find many tutorials on flipping the axles on popups over, which increases ride height. Some of the folks who post there have done this with ZERO WELDING.
Laredo
Re: Rockwood Popup
Postby MikeyLikesIt » Fri Feb 24, 2012 11:34 am
I think we are going to go the spacer route as I want larger wheels too.
The outriggers will also be cut down so that the width of the frame is 5'.
MikeyLikesIt
