I fully expected some oil canning when it got warmer.
Sun was out today and the side heated up and EEEK!!!
Not sure if you can see it between the two pics
First cold after I installed and second, camera wasn't pointed there but quite a bit of oilcanning
I know I'm not going to be able to do anything about it while the weather is still cold, but when it gets warm if I pull the front corner and trim the aluminum back and reinstall the trim, will that help the situation?
