So how do I extend a line, without losing my parallelism to the outside profile...? (Hoping it's not an eyeball kind of a thing!)
Re: How to do mirror, extend, line offset, etc.?
Postby Chris Fullmer on Wed Mar 03, 2010 1:21 am
Just use the pencil tool to continue the line. If you start at the end of the line, then run back on the line and pause for a second, then move forward, you should get a pink line that is parallel to the reference line. So it will be an extension of the line you are starting from.
TheDuke wrote:I"ve used the "pink line" method since I started with SU, and it works every time. After awhile, it becomes sort of natural to keep things in a plane. Just hang in there.
mikeschn wrote:So how do I extend a line, without losing my parallelism to the outside profile...? (Hoping it's not an eyeball kind of a thing!)
