ioan wrote:I went to Lowes and Home Depot and they don't have 1/8" birch plywood. They only have 1/8" hardboard panels.
What should I use? The thinnest plywood they have is 5mm (which is about 1/5")
Should I use hardboard panels? 5mm plywood? Something else?
Any suggestions are welcome.
halfdome, Danny wrote:If you could give us a general idea of your location someone could help you find a source.
I get my 1/8" Russian Birch at Cross Cut Lumber in Seattle.Danny
halfdome, Danny wrote:There's a Cross Cut Lumber in Portland & Eugene.Danny
linuxmanxxx wrote:the .5 luan at the box stores works perfect and is inexpensive.
Larry C wrote:When I finally found a source for 1/8" Russian Birch, I was telling the guy at the wholesale lumber yard what I was doing. He said "your using this plywood on the outside of a trailer, it's NOT EXTERIOR PLYWOOD" My question is: Has anyone had a problem with Russian Birch delaminating?
linuxmanxxx wrote:Reread what I said about underlayment and not finish. If it is used for a base that then has a waterproof agent and then covered by another physical substrate (aluminum, frp, or canvas) and then sealed it will last many years. If you leave it exposed to the environment with only paint or some other liquid based coating it will delaminate because of the properties of what it was built for. Think about it as there are zero houses built with exposed plywood and they are covered with tar paper and then shingles and the plywood doesn't rot. There is wood siding or cedar siding on the sides but vertical weather properties are nowhere near as harsh as the more horizontal portions due to both UV and water access to them. Any wood exteriored TD requires lots of chemicals to protect it as well as high quality wood and to me not worth the trouble in the long run but we all have our preferences. I like aluminum as its UV tolerant, waterproof, light, and won't breakdown under the elements and if glued correctly won't have any oil canning or visual defects.
