SC , I’m guessing the cold heavy air falls off the mountains and accelerates across the prairie , which I’m thinking is where you are huh ?
Plan ahead and ballast up ...the more weight Low on the trailer , the less likely it will be affected as much by the high cross winds ... to a point anyway ...
working on it wrote:Not meaning to hijack this thread, but: I most likely will never get up to Wyoming to see the endless winds there, but it brings up a related question. I, for one , am using Andrew's weight balance calculator for designing and moving weight aound for best effect. The calculator shows the center of gravity, LCG, horizontally, in relationship to the rearmost edge of the trailer. But, in view of wind effects and overall trailer handling on the road, I was wondering whether or not someone (angib, perhaps?) has a corollary formulation to locate the vertical component of the center of gravity? In rough form of course, since no height measurements are called for in the basic balance spreadsheet, much less the squat imparted to the tires and suspension with load.
slowcowboy wrote:gpw.
this morings current weather in pavillion. wyoming.
west wind at 20 something mph. temputer at 27 degreas. wind chill feels like 5 below zero with the wind blowing.
slowcowboy.
