GuitarPhotog wrote:I installed mine with the aluminum side facing in.
Yesterday.
It seems logical to want to reflect the interior heat back in, right?
<Chas>
Yesterday.
<Chas>
ioan wrote:Man, I posted this in the wrong place... I'll x-post in the right one.
GuitarPhotog wrote:You don't "reflect cold"
Cold is the absence of heat.
GuitarPhotog wrote:Since I'm insulating a metal trailer, putting the foam side out doesn't add anything to the ability of the outside to reflect heat out, therefore I put it on the inside.
aggie79 wrote:I believe radiant barriers only work if there is an air gap, so if the foil of your insulation is tight to plywood there will be heat conduction but not radiation.
