I could not find any grade of plywood that was not warped or full of knots. Even the finished one side was terrible.
Then I found out that 1x2 maple is not 1x2, it is .75x1.5.
It is amazing that you can sell a start dimension and not actual dimension. Start dimension means they start with a piece that is 1x2 and after planing it down, it is .75x1.5. You pay for the saw dust.
The 15/32" (what's with this?) finished one side is $21.99 a sheet.
I then check with True Value Hardware and they have 1/2" Luan that is perfectly flat and smooth finished both sides for $20.00 a sheet.
I then ask what is Luan, as the finish is cabinet grade, and he tells me that it is the part of mahogany that is not used for furniture. It is a very good looking finish. I will use this for my external walls, floor and cabinet faces and stain and finish it. It comes from Honduras.
It is amazing some of the trash that these box stores get away with selling. The 15/32 plywood, finished one side was warped, split grain, knotty and very rough.
I was so thrilled to find this 1/2" Luan.
I will never buy plywood again!!!!!!!!!!!!!!!!!!!!!
