I've had nothing but problems with plywood
Re: I've had nothing but problems with plywood
Postby Richkaci » Tue Mar 06, 2012 6:45 pm
Mike, your teardrops are built with such care and skill, do you have a shed you could put your campers under to protect them from the elements. Even if it was just 4x4's and a tin roof wouldn't that help?
Richkaci
Postby mikeschn » Tue Mar 06, 2012 9:09 pm
Yes, I am going to have to do something... someone recommended we start a shed/carport thread... I will probably do that too!
Postby GPW » Wed Mar 07, 2012 6:02 am
4X4s and a tin roof ... 23532 EXACTLY !!! :thumbsup:
Postby Larry C » Wed Mar 07, 2012 7:51 am
I like the one Roly made, but it's not currently in his album. Maybe he would show us again.
"If its worth doing it's worth doing Light"
http://www.tnttt.com/viewtopic.php?f=50&t=35852
Larry C
Images: 78
Postby jonw » Wed Mar 07, 2012 8:40 am
jonw
Titanium Donating Member
Images: 163
Postby Dan & Julie CO » Wed Mar 07, 2012 8:54 am
I didn't do the whole raka fiberglass thing,The harsh chemicals & pricing was a factor.
On my build I scaled back and did the mineral spirits and spar varnish external house paint route.
So far so good,that being said I have stored mine in the garage. :worship:
Dan & Julie CO
Images: 56
Postby Dan & Julie CO » Wed Mar 07, 2012 8:59 am
Anyone on the forum try metal 2x4 studs and fiberglass panels ?
Dan & Julie CO
Images: 56
Postby angib » Wed Mar 07, 2012 4:17 pm
mikeschn wrote:Yes, I am going to have to do something... someone recommended we start a shed/carport thread... I will probably do that too!
If you do, the discussion will just change to "how do I stop my teardrop shed/carport from deteriorating?".....
angib
5000 Club
5000 Club
Images: 231
Postby mikeschn » Thu Mar 08, 2012 7:29 pm
Dan & Julie CO wrote:Anyone on the forum try metal 2x4 studs and fiberglass panels ?
Dan,
Good question... I'd like to know too!
@Andrew,
Do your carports delaminate over there in Old England?
Postby bohemian » Fri Mar 09, 2012 12:34 pm
Mike
Was that the luan that has a life time warranty against delamination?
I used a luan product on a couple of PDRacer sail boats my daughter and I built.
This stuff has stamped on the back, Life Time Warranty against delamination. I hope this is not the luan you used. :worship:
Wayne
bohemian
Images: 233
Postby mikeschn » Fri Mar 09, 2012 4:35 pm
bohemian wrote:Mike
Wayne
Wayne,
Nope, mine didn't have anything like that stamped on the back. Maybe that's what I need to use next time?
Postby newrollo » Fri Mar 09, 2012 6:06 pm
Hi Mike,
Like what has been hinted, the weather in Michigan can unglue anything. Ive scootered (Zuma125) and skied in every month since Nov. Thanks for all the advise and vision.
newrollo
Postby GPW » Sat Mar 10, 2012 8:21 am
If you guys are going to build wooden TDs then they really deserve to have a shed/cover/garage of some type ... I recall many old friends that had wooden boats , all stored inside a garage or shed ... many lasting decades , same for TDs too huh ??? Wooden things left outside in the weather go to heck pretty quick ! :frightened:
Not a perfect solution as things stored inside get Dusty ... :roll: Easier to deal with than ROT !!! :thinking:
Mike , finish your new Foamie , forget about Rot problems ....think about new problems like Frozen Turkey strikes ... :o
Postby bohemian » Sat Mar 10, 2012 10:08 am
Mike
Here is the ply I was talking about. I'm not sure about long term but it looks good on paper(video). :thumbsup:
http://www.youtube.com/watch?v=K1_klNEO27w
bohemian
Images: 233
Postby Verna » Sat Mar 10, 2012 5:57 pm
Speckles, my last dog, is buried in the back yard in a box made from left-over plywood from my bathroom remodel. The plywood is an orangish-color, tongue-in-grove, 3/4" thick, "moisture resistant" plywood from Lowe's. The ground is still level where she's buried....so I guess the plywood is still intact after two years. I'd say that's pretty good advertising for "moisture resistant".
Verna
Indianapolis, IN
Verna
Images: 49
