Plywood side thickness?
Postby petertl » Thu Mar 08, 2012 7:46 am
I am starting a 4' x 10' modernaire. I need to save time and weight. I would love to do a sandwich wall but want to get the thing built.
If using a quality grade ply, will 1/2" be good? 5/8"? 3/4"? It will be used as a utility trailer hauling tools more than camping.
Thanks,
Peter
petertl
Images: 15
Re: Plywood side thickness?
Postby grant whipp » Thu Mar 08, 2012 12:47 pm
Hi, Peter!
I would suggest a "sandwich" of 5/8" plywood core that is "cookie-cut" to save a lot of weight, then a 1/8" inside paneling, followed by a 1/4" outside sheathing. I know you said you won't be sleeping in it, but just in case, it wouldn't hurt to put some 1/2" bead-board insulation in the voids of the plywood. It's not that much extra work, and you get a nice solid light-weight wall ... :thumbsup: ...!
Good luck, and as always ...
CHEERS!
grant whipp
Teardrop Manufacturer
Images: 117
Postby petertl » Fri Mar 16, 2012 6:20 am
Yes, Ideally I would love to do sandwich walls. I am trying to get the build done in a few days, total. (weekender) I would love to use 1/2" plywood for the sides if someone else has had success with that.
Thanks,
Peter
petertl
Images: 15
Postby bobhenry » Fri Mar 16, 2012 7:21 am
I used 7/16 fiberglass faced zip panel ( fancy osb) on the 4x7. Floor and body cut and built with spars installed in in about 6 hours.
( It's the little stuff that takes forever ) :oops:
Here is a link to the build if you are interested.........
http://www.tnttt.com/viewtopic.php?f=50&t=38489
Postby jonw » Fri Mar 16, 2012 9:31 am
I used 5/8 marine plywood for my sides and it was plenty stiff. As I was building it I was wondering if I could have gotten by with 1/2in. but then I'd have to build out door and window frames to accommodate standard molding and window thicknesses. It's all about tradeoffs...
jonw
Titanium Donating Member
Images: 163
