halfdome, Danny wrote:eamarquardt wrote:halfdome, Danny wrote:I found trimming with a 1/2" flush trim bottom bearing bit that it's too fast and will melt the aluminum.
A Freud 42-118, 3/4" flush trim bottom bearing bit slows it down and it cuts like butter.
It has a 1/2" shank so you'll need a 1/2" Colette if your router doesn't have one.Danny
I'm confused (which isn't a new thing). A 3/4" bit will have a higher speed at the cutting edge than a 1/2" diameter bit. Do you slow down the router with the 3/4" bit.
Thanks,
Gus
Ever noticed they stagger runners on a track? The inside guy is back behind the outside guy since the track is longer on the outside vs the shorter inside.
If you put larger wheels and tires on a car your speedometer will say your going slower since it's based on revolutions of the stock tire.
A larger router bit has a greater circumference; therefore in one revolution it will travel a farther distance which is slower at each cutting edge.Danny
