Window installation
Window installation
Postby nrody » Sun Mar 04, 2012 11:33 am
Can anyone provide instructions on installing the curved radius windows. I bought my windows last year and they did not have instructions I also lost the screws. OM :o G I have lost my screws :o
nrody
Nancy
nrody
Re: Window installation
Postby Martiangod » Mon Mar 05, 2012 12:41 am
I trace out the trim ring and cut with jig saw
Cut from the outside, if you have a finished surface, cover your work area with painters tape so shoe of the saw doesn't scratch
The flanges on the newer windows are getting real small, so you need to be acurate.
If they came with foam gasket, i throw them away and use butyl tape, Seen too many production trailers leaking around the windows becasue of foam tape.
Screws, Just use pan heads, you will be able to figure how long you need by your wall thickness. I needed 1 1/2" screws
Before installing, just take all them screws, poke em into a piece of cardboard and spray paint them black, if your frames are black. I like satin black or semi gloss...gloss looks kinda yuk
Look at inside of window frame you will see groove where screws go, angle your screw gun away from the glass a bit, so the screws don't come out on the finished side of frame.
Thats how I got my window, i had to change it out because some doehead on the assembly line was just rammin the screws in and the screws penetrated the finished side. Oh well, I won that one...lol
After installing screws, trim the butyl around the window that has squeezed out, a plastic knitting needle works well, or very carefull with knife
I always run a bead of clear polyurethene caulk around window when done.
I try to leave my trace line there when I cut, I'd rather file or trim then have the hole too big
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby Treeview » Mon Mar 05, 2012 12:52 am
Which is worse...loosing your screws...or...having a screw loose!
Thanks for the instructions. I'm going to be installing windows soon so this is timed perfectly.
Treeview
Images: 30
Postby mckenney56 » Mon Mar 05, 2012 12:45 pm
Treeview wrote:Which is worse...loosing your screws...or...having a screw loose!
My screws all fell out years ago.
mckenney56
Images: 129
Postby FlyerSkip » Tue Mar 13, 2012 12:24 pm
What's a screw? :shock:
A one legged duck swims in a circle.
FlyerSkip
Images: 28
Postby Martiangod » Wed Mar 14, 2012 8:00 am
FlyerSkip wrote:What's a screw? :shock:
Chris
Martiangod
Images: 432
