ioan wrote:Hi,
In few days I'm going to order the aluminum for my teardrop. Does anyone have detail pictures (or schematics) on how to install the aluminum and molding?
Also I'll be interested to see some hatches and how are they installed (I still have to make mine) and how to make the hatch as water proof as possible.
I saw this schematic (the top one). Is this the kind of molding should I get or right angle profile?
Thank you!
I used this RV trim, and installed it as the graphic shows (Top and bottom both!). As Tom (aggie79) stated it has a vinyl insert to look pretty, got mine from Redneck trailer supply. It took the bends nicely. I tried annealing the first one and the second one, I just bent it over slowly and it was a breeze, even the tight radius of the hatch. If you get a right angle profile, you'll have a hard time bending it, you'd need to trim it and anneal it, and fight with it and then go get the otherstuff anyway
It does have it's uses along straight lines though.
I also had my side plywood walls hanging down below the frame and used regular C channel all along the bottom as Danny noted. I didn't plan it but I had routered it and it just happened to be the perfect thickness.
