... So, this week, I worked on making my own flooring out of brown Kraft paper.
You can see the basics for making a Paper Bag Floor here:
http://www.familycorner.com/homegarden/ ... loor.shtml
But, as you probably know by now, I have ‘One-more-thingitis’ and just can’t seem to do things fast. I do them My…Ah…way.So, I bought a couple rolls of Kraft paper, some Minwax Polyurethane and then visited a local native black oak tree (Quercus kelloggii) to pick up some fallen leaves and preserve and strengthen them by ironing them between waxed paper.
I stained some of the Kraft paper close to the color of the freshly gathered, unfaded leaves:
Using a brightly colored gel pen, I copied the outline of each leaf onto the stained paper, drew in the veins, and cut them out. To ensure that the colors wouldn’t run, I sprayed each “leaf” with varnish.
Then, I set about laying the basic brown paper floor. Here is a picture of part of that, without leaves:
After that had dried, I tossed the leaves up in the air and let them fall where they may, arranging any that didn’t suit me. I then added them using the same procedure that the brown paper had been laid with.
After that was dry, I pulled off the blue painter’s tape andpulled too much:
(I scored the rest of the way with a knife before pulling any more tape!)
That little Oops! was easily fixed with a “damaged leaf”. Mother Nature isn’t perfect and neither am I.![]()
After the leaves had dried in place, I began ‘topping’ the floor with more layers of Minwax Polyurethane. Here, you see it with the second coat freshly applied:
…Two coats down and four more to go! Then, I’m supposed to wait 3 days before ‘using’ it and 7 days before walking on it. But, there are lots of other things to do while I wait….
I will walk on it after 7 days. I'm using the Minwax polyurethane that is a water-based, oil modified mixture. The can says it can be used as a floor coating substance. People have been using polyurethane instead of wax on floors for a good 25 years or more with great success. They just don't tell others about it. As a bonus, paper floors are easy to repair. You just add another piece of paper and coat with another layer of polyurethane.
The down side is how long it takes to lay the paper flooring. It took me a full day to mask, paste the paper and leaves, and put on the first coat of polyurethane in that small trailer. That doesn't include creating the 'leaves', which I did while watching television nor am I including the last 5 topcoats of polyurethane.
Minwax recommends lightly sanding with 220 grit sandpaper between coats if you're applying it to wood; however, sanding in this application would definitely damage the paper, even with a fine grit like 220. The various paper-laying instructions that I have read do not suggest sanding either; but, they do mandate that each of the 4 to 6 coats of polyurethane be put on in rapid succession, as soon as the previous coating is dry. Once all coats are on, you do not disturb the surface in any way for at least 24 to 72 hours, longer being better. Minwax instructs not to use throw rugs on it or walk on it for 7 days. From that, I am assuming that a full cure takes 7 days and, chemical bonding can take place during that time. I have known people who mopped coats of polyurethane over vinyl kitchen flooring with no sanding and they have had no problems with that application.
I collected the leaves but elected to use hand-made copies of the actual leaves for a couple reasons: 1) any dampness still in the leaves could be problematic once encased in polyurethane and, most importantly, 2) since mine is a walked-on surface, the weight of people might eventually pulverize actual leaves. Your leaves will look great on a tabletop!
Parnold wrote:Will there be enough polyurethane on it so that it will be smooth, or will it have a slightly textured feel to it!
Paul,
As I thought about your question, I decided that I need to explain a little more in case you or someone else needs this information.
The reason for wadding up each piece of paper is to give it random small breaks in its surface so that more polyurethane will be absorbed at those places, thus, changing the shading there. The color also changes on the torn edges. The more you wad the paper up and even which side you put up can change the shade and ‘print’ of the piece you are working with. When you polyurethane the piece down and smooth it out, the wrinkles disappear but not the newly added color shadings. As the pieces are placed and begin to dry, air bubbles develop under the surface. Even though you smooth these bubbles out to remove the air pockets, in some places, the paper will have stretched. This is what leaves a sort of raised wrinkle here and there and gives it that nice texture. The color changes and raised wrinkles are what give it that leather or sandstone look.
I have just finished putting on the 5th coat of polyurethane and I can tell you that, yes, it will still have a slightly textured feel to it, but not from the original wadding of the paper. The wadding wrinkles are gone.
One more tip: Get and wear some disposable gloves and change them about every half hour. This is because you use your hands to smooth out the wrinkles and release air bubbles. You hands work the best to do this. However, after about half an hour, some of the polyurethane starts to dry and flake off. If you have disposable gloves on, that's easy to fix. You just replace your gloves with a new pair. Also, when you take off the old gloves, save them. The inside of the glove is still good and can be used to contain a wet sponge brush or paint brush so you can use it for your next application. You just stick it inside the palm area and twist the wrist area around the handle until you're ready to use it again.
Eaglesdare:
If you are putting this type of paper floor over wooden boards, please be aware that every seam will show. My cabin is plywood but it has one seam that shows. If you go back to the picture of the floor, you will see a part of that seam in the pictures. It is about 8 inches out from the benches, near that big brown leaf. That one bit of seam doesn't bother me as even vinyl flooring seams show; but, if you are laying boards side by side and don't put something over all those board joinings, this type of floor might look a bit strange.
That said, this paper floor is "on trail" in my trailer. If it holds up well, I plan to put something similar down on my den floor in a few years. For that, I plan to use several colors of stained paper and make a mosaic pattern from them. You can use Minwax Wood Finish to stain the paper as it is compatible with Minwax's polyurethane.
Steve Smoot wrote:Where did you get that idea?
A local decorator's shop owner was creating a paper floor in his new addition when I was there, shopping. That was about 7 years ago. I'm guessing that thousands of people have walked on it since then and the floor still looks good. Additionally, I had a friend who used polyurethane on her kitchen vinyl floor once a year instead of constantly waxing it. I remembered these experiences and looked up 'paper bag floor' on the Internet. I have done decoupage in the past; and, really, the trailer floor is just a giant decoupage. The leaf idea was something I dreamed up on my own.
GPW wrote:Great looking floor ... recycled !!The torn edges really Make it look “natural”
eaglesdare wrote:GPW wrote:Great looking floor ... recycled !!The torn edges really Make it look “natural”
well its only recycled if you use old paper bags. but we are using the rolls of brown paper you buy at craft stores of lowes/home depot.
i don't think hubby is going to like this, but i have to bring my floor into the house sometime today. we are expecting rain tonight/this weekend. i can't have that floor getting wet yet, it is so far from being waterproofed at this stage.
i have to remember also to keep my dog away from my work area. simba kept laying down right on the glue. i had a hard time picking glue out of his fur. ick.
