corncountry wrote:I have built two tears using 1" steel tube. I just cut the foam for a snug fit---no glue. Both of my tears have plywood inside and aluminum on the outside. I used a saw to score the foam about 3/4 of the way through to make the radius bends on the top. Just a note--make sure your foam board measures 1". The first foam I bought was 1/16" oversize on thickness --had to take it back and go to another store to get some that was a true 1".
Jim
Siouxgirl2 wrote:Thank you Brian,
I seem to struggle getting around in the right places of this board at times. I think I see the post on the kerfs. I think I cut the kerfs on the opposite side as I'm seeing and was bending it the opposite way as in that post. I was bending it so that the gaps were outside of the curve (if that makes sense) rather then on the inside and was thinking I should fill it with spray foam or something. Again, I am a little green on this stuff. I see I just asked Jim a question about his build as well that I finally found he used rivets (not sure which kind) on one and VHB tape on the other. I have so many questions and sometimes I can find the answer and sometimes I get lost. Thanks for directing me to this thread as I didn't realize there was a thread just devoted to foam.
