questions about "black goo" asphalt emulsion
Re: questions about "black goo" asphalt emulsion
Postby Glenn Quarles » Sat Mar 17, 2012 11:00 pm
What about the black fence paint? It is kinda like oil or thin tar stuff right?
Glenn
Glenn Quarles
Images: 34
Postby Big Dave » Sun Mar 18, 2012 10:15 pm
This does look like a good option:
http://www.tractorsupply.com/gardner-gibson-fence-post-black-beauty-asphalt-fence-paint-1-gal--3414185
and only $15 a gallon.
Well, after reading these reviews maybe not:
http://reviews.tractorsupply.com/0519/341417799/gardner-gibson-fence-post-black-beauty-asphalt-fence-paint-5-gal-reviews/reviews.htm
The best reviews seem to be for this product:
http://www.tractorsupply.com/paint/fence-barn-paint/lexington-professional-fence-paint-black-5-gal-3414290
But, that's a latex, which puts me back on my original plan of Zinsser and PPG Manor Hall.
Big Dave
Postby egjacks » Fri Mar 23, 2012 11:26 pm
I went ahead and used the Tite Seal brand window flashing, I never liked the idea of "painting" on asphalt. The flashing stuff I used is talked about in a sticky about undercoating alternatives, and was not greatly more expensive than the asphalt emulsion. seems to work really well. Thank you all for your replies.
Eric
_________________
~If I fall flat on my face, at least I am moving forward.~
egjacks
Postby Scouterjan » Sun Mar 25, 2012 12:04 am
any thoughts on Rino Liner. Its available in litre, cans with the activator. Sure it tough on PU boxes, or Gravel Guard used by body shops for rocker panels, its available in large spray cans, rattle cans
Jan
Scouterjan
Iron Man
Postby working on it » Sun Mar 25, 2012 12:34 am
Why not use spray on automotive undercoating? Also in rattle cans, also at Tractor Supply. I'm using it on my TTT. I've also used it for many years on various vehicles, that have been exposed to many more miles thru worse conditions than a TTT or TD will probably (or should be) exposed to. An occasional inspection and/or touch up is all you'll ever need. And, you can always have a spray can handy to do so, when on the road.
173193172890148599
working on it
Images: 457
Postby Nobody » Sun Mar 25, 2012 9:45 am
working on it wrote:Why not use spray on automotive undercoating? Also in rattle cans, also at Tractor Supply. I'm using it on my TTT. I've also used it for many years on various vehicles, that have been exposed to many more miles thru worse conditions than a TTT or TD will probably (or should be) exposed to. An occasional inspection and/or touch up is all you'll ever need. And, you can always have a spray can handy to do so, when on the road.
I used the black asphalt emulsion on my floor (underneath) when I built the TD in 2006. It dried fairly quickly & wasn't a great problem for me to clean up (don't understand what all the objections are about)? I also added 1" 'blueboard' insulation after coating with the black stuff. Used construction adhesive & plain wood 'batten's to hold the insulation in place. Thru more'n 12K miles over all kinds of roads/terrain Never had any problem with road debris causing any damage to either the 'coating' or the insulation. In 2010 I was rear ended while on a short trip. Trailer was damaged but useable. After returning home & following the insurance settlement I repaired the damage myself. In the places where the impact had 'splintered' some of the floor joists you could see where the emulsion had penetrated approx 1/16" or so & the wood (spruce) behind the coating was still like new. No moisture had ever penetrated it. The collision did open up a couple of seams on the wheel wells inside the cabin which allowed water to enter. After discovering this & drying it out thoroughly, I sealed the seams inside with caulk & CPES. Underneath I used the 'rattle can' of automotive undercoating since it was much easier than 'painting on' the emulsion again (upside down). The aerosol undercoating appears to have done a good job sealing. I don't expect any problems, seeing how long the original emulsion has lasted to now but, I carry a can of the spray-on undercoating for 'just-in-case'.
Some of the damage to my TD showing the emulsion coating & splintered floor joists
After using the spray-on undercoating on the open seam
Harvey -
Nobody
Images: 342
Postby DMcCam » Mon Mar 26, 2012 11:36 am
We used two part spray on bed liner.We'll see how it works out...
DMcCam
