Over or between wheels
Postby GregB » Wed Mar 15, 2006 1:54 pm
Gerdo,
I like the look. Its very clean. Where did you get the fender flares that you have on there?
GB
I'm not dead, yet. I'm feeling better.
GregB
Images: 108
Postby Gerdo » Thu Mar 16, 2006 12:23 am
They are the outside edge of my steel fenders.
Gerdo
Images: 156
Postby angib » Thu Mar 16, 2006 4:01 pm
Greg and all,
Fred in Alaska has pointed out an error in the axle layout I posted before - I had underestimated the width of the hub, so here is a corrected version:
You could still, just, get this layout to work, but you would need to increase the cutouts in the body that the end of the suspension arms would move into at full bump - it's shown with zero clearance, so it could do with being 1/2" deeper and 1/4" wider. The alternative is to get an axle with enough down start angle that it doesn't reach the body at full bump - but that's not easy.
Andrew
angib
5000 Club
5000 Club
Images: 231
here's my version of over the wheels
Postby doctormap » Thu Apr 13, 2006 10:36 am
Here is how I plan to build over the wheels:
http://tnttt.com/album_ ... ic_id=7647[img]
I am using the "Lil Diner" building CD I bought from Steve Frederick, with some minor modifications. I can't afford to buy a 5 ft. wide trailer, so I am building over the wheels. I will be trying to build as light as possible, as I plan to pull this behind my '48 Studebaker, to car shows.[/img]
Doctormap
doctormap
