Kayak Builders, wooden boat builders...
For those of you that have seen the de-lamination of my giant teardrop, you understand why I am asking this question...
I am planning on building an Optimized Winter Warrior for my next build. But I keep getting stuck on the materials...
If I build with pine, and cover it with aluminum, there are many screw holes where water can get in. So aluminum doesn't seem like a good choice.
If I build with plywood, does it have to be marine plywood, or can I use interior plywood? What can I protect the plywood with to prevent delamination?
Canvas?
Fiberglass?
Filon?
Notice I've been suggesting membrane type products to cover the plywood, but Filon wouldn't cover the endgrain of plywood.
So that leaves canvas and fiberglass. I could use 4 oz fiberglass and several layers of resin, seems to me that would seal the end grain of plywood. At that point, can I use interior plywood, or must I use marine plywood?
And what about canvas? Would it seal the endgrain of plywood?
Your thoughts?
