1/2" moisture resistant lauan?
Postby mikeschn » Thu Apr 05, 2012 3:52 pm
Does anyone here know where I can get 1/2" moisture resistant lauan?
I suppose I could use the 1/4" moisture resistant lauan from Home Depot, and glue up 2 to make it 1/2" (nominal of course). Heck that might even be the answer to making plywood larger.
But I think I'd rather start with 1/2" stuff.
Any ideas?
Re: 1/2" moisture resistant lauan?
Postby jstrubberg » Thu Apr 05, 2012 4:54 pm
Mike, I've never seen anything other than 1/4 inch and 1/8 inch. A quick Google search turns up no sources either.
I don't think there is such a thing.
The more stuff I take along, the more time I spend taking care of my stuff!
jstrubberg
Postby mikeschn » Thu Apr 05, 2012 5:18 pm
I used 1/2" moisture resistant lauan on my escape hatch build. Bought it at Pontiac Plywood. They no longer sell it. :cry:
And according to this site, I might have to get the Okoume... http://www.columbusmillwork.com/specialty-plywood.php
They only have moisture resistant lauan/meranti in 1/4".
Postby GuitarPhotog » Thu Apr 05, 2012 6:44 pm
What's magic about luan? Wouldn't another 1/2" moisture resistant plywood do as well?
You can tell I'm not a wood worker, so if this is an idiotic question, ignore me and move on with your discussion :lol:
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby mikeschn » Thu Apr 05, 2012 7:21 pm
Only that the lauan is affordable. The marine plywood is much more money. But of course, the price is forgotten very quickly...
Postby Martiangod » Thu Apr 05, 2012 9:22 pm
What about mahogany?
And whats affordable, doing it once, or every couple years?
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby GPW » Fri Apr 06, 2012 5:07 am
There’s this old saying , that I’ve come to realize is the BEST advice ever.... "The quality is remembered long after the price is forgotten, so build your teardrop with the best materials...” :R
Postby mikeschn » Fri Apr 06, 2012 5:35 am
I just picked up a book on stitch and glue boat building, and just finished reading the chapter on plywood. It says, If a boat is meant to live at a dock for weeks at a time or on a trailer year round, choose at least a moderately durable wood species. A less-dense panel such as okoume is fine for kayaks, rowing shells, and other small craft that will be stored under cover. But it may discolor or even rot if exposed to the weather for months at a time unless all surfaces are 'glassed. Among the durable or moderately durable tropical hardwood species are khaya, sipo, sapele and meranti.
Meranti, as you will recall is another name for Lauan!
My local plywood supplier doesn't have those fancy marine plywoods.
http://www.publiclumber.com/store/pc/vi ... ategory=21
In the 1/2" size marine birch is $69 a sheet.
Teak is @219 a sheet... :NC
I could go to Boulter Plywood, but it's 720 miles each way... 12 hours and 41 minutes each way. :frightened:
Postby mikeschn » Fri Apr 06, 2012 5:49 am
Ah ha... I found it!
http://marine-plywood.us/mahogany_meranti.htm
P.S. It's only a 2 1/2 hour drive!!! :)
Postby jstrubberg » Fri Apr 06, 2012 8:45 am
Yeah, finding specialty woods is becoming a pain.
Around here, even Okumwe means sitting down in front of a computer screen and trusting the guy picking your shipment knows what he is is doing.
jstrubberg
Postby doug hodder » Fri Apr 06, 2012 9:12 am
Mike...see if you can find some 1/2" MDO, (medium density overlay)...made for the sign industry and has a nice smooth finish on it can be had primed as well. I used it on the Voyager. Doug
Postby Martiangod » Fri Apr 06, 2012 9:35 am
Mahogany skin wood be nice :) ( pun intended )
Build an exoskeletin out of cedar or mahogany, dado in the ply skins, embeding them in gorilla glu or epoxy
Once sealed, all endgrains would be embedded.
Use stainless or brass exposed screws, or copper nails spaced for appearance, Put a radii on the outside corners of the exoskeletin. epoxy, glass or poly the exterior
Vintage aluminum windows and doors and stainless piano hinges
or make own window frames out of mahogany
Bottom paint lower 10 inches nice marine red, with a white breaking stripe
Couple nice stainless deck vents
Deck plates for cable hatches
Theres 100 year old mahogany boats out there, should last forever
Chris
Martiangod
Images: 432
Postby GPW » Fri Apr 06, 2012 9:54 am
Mike, that seems to be some really Nice ply !!! And what, about twice to three times as expensive as the junk (that fails so quickly) they sell for plywood at the box stores... That seems pretty reasonable in the long run ... :thinking:
Postby hull je » Fri Apr 06, 2012 10:14 am
mike i agree with doug about the mdo,used it on the boat i built.mdo weighs about the same&the price also close to inteior/exteior plywood.also there is hdo which is used for concert molding(such as large buildings.3/4 4/8 sheet weighs 75 lbs...googel is your friend...
hull je
Postby jonw » Fri Apr 06, 2012 12:36 pm
There are multiple types of Mahogany: luan, meranti, okoumi, etc.
Here's a good source of information, and they will ship to you if you can afford the postage. http://www.boulterplywood.com/. Look under their marine plywood.
At least you'll see what's available and what to ask about locally. Often better lumberyards can special order stuff like this for you...
jonw
Titanium Donating Member
Images: 163
Users browsing this forum: Google [Bot] and 15 guests
