to the dutch owen grues.
Re: to the dutch owen grues.
Postby Woodbutcher » Fri Apr 06, 2012 9:03 pm
Hey Slow, as long as you can drop the feet through the oven or stove racks it will work. I have cooked on my propane stove many times. Anything you can do in a frying pan can be done on the stove in a Dutch Oven. In the oven they work the same as any cast iron would. Keep practicing, if you learn to master the DO you will catch a girl for sure. :lol:
Woodbutcher
Postby Corwin C » Sat Apr 07, 2012 9:00 am
slowcowboy wrote:so if I set the owen for like say 350 and pop in my dutch oven. I can get the same as 350 out of charcoals? Pre-heat your DO a little and it's even more predictable than charcoal.
what about the white gas stoves? This works for anything that doesn't need top heat. Keep your flame low and don't try to rush it. It works on propane too.
I don't know if I'm a "guru" or not, but I have learned that even mistakes are rarely inedible. As long as it won't harm the oven (temperature shock, impact, extreme heat) don't be afraid to try it. I've even baked bread with charcoal on top and propane on the bottom (gives infinite control for that perfect bottom crust.) BTW ... I'm still experimenting.
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Postby Betsey » Sat Apr 07, 2012 10:14 am
slowcowboy wrote:I CAN set the do in the oven at home and it will work?
If you are using a camp oven (one with legs), it is easier to use if you place it on a cookie sheet or jellyroll pan before putting it in the oven. That way, you aren't battling with the legs & the oven rack.
If you are using a regular Dutch oven (no legs), it was intended for regular stove/oven use, so no problems.
slowcowboy wrote:so if I set the oven for like say 350 and pop in my dutch oven. I can get the same as 350 out of charcoals?
Works the same... 350º with charcoal or in a regular oven is still 350º.
Betsey 8)
Betsey
Images: 35
Postby Dale M. » Sun Apr 08, 2012 9:27 am
DO can be used on stove top or in over, great for soups, stews and any other cooking/heat applications....
Want to upgrade from DO cooking try 'Pressure Cooker" applications (stove top only) ....
Dale
Dale M.
Images: 18
Postby bobhenry » Mon Apr 09, 2012 12:20 pm
I made ice cream in mine for the cast iron cooking seminar I gave at the Crossroads of America gathering.
No stove top or oven needed ! :D
Images: 2617
Postby niget2002 » Tue Apr 10, 2012 3:57 pm
I've used mine many times for baked beans cooked in doors.
It also worked great for chili when the 'other' big pot couldn't be found.
niget2002
Postby GerryS » Fri Apr 13, 2012 10:26 pm
bobhenry wrote:I made ice cream in mine for the cast iron cooking seminar I gave at the Crossroads of America gathering.
I got to hear about this!!!!
GerryS
Postby tonyj » Fri Apr 13, 2012 10:45 pm
What the hell is a grue?
tony
tonyj
Images: 160
Postby Maureenm » Sat Apr 14, 2012 8:47 am
A "guru" in slowcowboyese, ;)
Maureenm
Postby Aaron Coffee » Sat Apr 14, 2012 9:40 am
I use my camp DO many times on the kitchen gas stove to make magic beans, use the burners for browning hamburger and bacon, then use the oven for the rest. I do wonder if I am using to high of a flame on the stove top though as the seasoning has burned off of the center of the DO. I have also heated up the DO on a porcelain top stove(the ones that have to have contact to work) and it worked to heat up beans.
If I could shut my brain off, I could save myself alot of time, money and effort.
Aaron Coffee
Images: 26
Postby Mukilteo » Sat Apr 14, 2012 12:49 pm
Heck, I diden't notice "guru" was miss spelled until it was mentioned.
Built in translater? Babel Fish maybe. :)
Eric
Mukilteo
Images: 18
Postby chorizon » Sat Apr 14, 2012 4:36 pm
tonyj wrote:What the hell is a grue?
It is pitch black. You are likely to be eaten by a grue. :D
chorizon
Images: 94
Postby wingnut » Mon Apr 16, 2012 10:44 pm
Hey, it's like Woodbutcher says, if you can drop the feet through the stove or oven racks, then you're a Grues. :beer:
wingnut
Images: 46
Postby bobhenry » Tue Apr 17, 2012 6:23 am
http://www.dutchovendave.com/recipes/dutch_oven_ice_cream.pdf
I had a big bell shaped bean pot and used a large glass jar to contain my ice cream mix and placed the ice in the pot. Be sure and wash the cast iron right away as the salt loves cast iron.
Images: 2617
Postby suckerpunched » Sun Apr 22, 2012 7:22 pm
The hell with spellcheck,,,,,I know what slow is saying......
If you see my harley on a trailer,,,,call the police cause it's being stolen...
suckerpunched
Images: 22
Return to Cast Iron
