MeelisV Tear DIY compressor ref.
Re: cabin rebuild - frame is ready
Postby Shadow Catcher » Sun Apr 15, 2012 5:59 am
Looking good :thumbsup:
Postby LDK » Sun Apr 15, 2012 7:13 am
I like how you're doing your build. It should be lite weight yet strong. :thumbsup:
LDK
Postby MeelisV » Sun Apr 15, 2012 11:32 am
last effort before working power ended -all work in 3 days is made only by my self
door holes
how the house meets wheels :?
surprise - yes i knew that new cabin is 10cm longer but surprise was that its not enough wide in front end
now need to cut and weld the frame
A woman has the last word in any argument.
Anything a man says after that is the beginning of a new argument.
MeelisV
Images: 105
Re: cabin rebuild - aluminium frame
Postby MeelisV » Tue Apr 17, 2012 5:09 am
door handle and lock
http://www.reimo.com/en/53238-door_lock ... for_25_mm/
roofwindow
http://www.reimo.com/en/38080-mini_heki ... _25_42_mm/
and door window
http://www.reimo.com/en/M31239-s_4_slid ... d_in_grey/
in my old cabin there was no roofwindow
or door window what i could open it means there was no vent what ever, only when you opened the door.
now there will be ventilated (with out fan) roofwindow (with insect stop and blind curtain) and doorwindows (with insect stop and blind curtain) what i can open and vent my cabin.
MeelisV
Images: 105
Postby MeelisV » Fri Apr 20, 2012 1:44 am
made one doorway and parts for one door
need to weld them
i hate that 45degree angle job - its not for me.
MeelisV
Images: 105
Postby MeelisV » Sat Apr 21, 2012 11:45 am
some more progres
door inner frame welded
after some time it hangs
between trailer frame and cabin frame is L-profile it holds cabin on frame
testing door lock
roof window
door is framed or trimmed how you say it
and there is this open P-profile on the edge between wall and roof
MeelisV
Images: 105
Postby MeelisV » Sun Apr 22, 2012 10:41 am
without stripes and arrows
second doorway is done
and started with insulation
MeelisV
Images: 105
Postby MeelisV » Sat Apr 28, 2012 1:10 pm
one rear light installed
its 3-1 tail-brake-turn
MeelisV
Images: 105
Postby MeelisV » Sun May 06, 2012 10:05 am
more pics.
second rear light and hatch lock
second door framed and upper sidelamp
insulated door and cabin front end
MeelisV
Images: 105
Postby Cliffmeister2000 » Sun May 06, 2012 10:40 am
Very nice looking build!
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby mikeschn » Sun May 06, 2012 4:16 pm
Looking really good. What kind of rivets did you use?
Postby MeelisV » Mon May 07, 2012 12:40 am
for now i used aluminium pop-rivets
i will look where needed i replace them with stainless pop-rivets
MeelisV
Images: 105
Postby MeelisV » Wed May 16, 2012 2:44 pm
door with ply inside
insulation
front cabinet
hatch opening
door lock
MeelisV
Images: 105
Postby aggie79 » Thu May 17, 2012 3:33 pm
That is one sweet teardrop! Incredible craftsmanship and design.
Postby MeelisV » Fri May 18, 2012 1:00 am
thanks
i will try to give my best - the second one must be better then first :thumbsup:
in some points there is easyer to work with wood and ply. but in some case there is better work with alu.
first tear build was from inside to outside now im doing from outside to inside and must say that fist case was easyer :thinking:
hope that we will "run" after week or two but finished will be in next winter that means with all accessorys and toys.
next :pictures: will be after some days.
ps. made my self a fotoalbum on paper and there is history from first build and new build till now and there is ~150 photos allready.
MeelisV
Images: 105
