I looked at:
http://cozywinters.com/shop/ew-rvhmp.html . It says the "average" current usage is 3 amps. Not to be a skeptic but manufacturers usually advertise what they think will sell their product. I looked at the pad on our queen bed and each side is rated at 3.5 amps at 16.5 volts d/c. As you're just driving a resistance heater (no motors) I'm guessing that it would work fine on 12 volts but would not have quite the heat output it normally would.
You might buy one, run it on 12 volts, see how it works, and measure the current. Yeah I know a PITA. If it doesn't meet your needs you pack it up nice and pretty and return it as I doubt that running it on 12 volts will harm it.
After you determine if it works, how much heat it will put out on 12 volts, and the current draw you can figure out how much juice it will take to run all night. I'm betting that it will take 25-30 amp hours. About half the capacity of a 100 amp/hour deep cycle battery as you don't want to discharge the battery more than about 50%.
You also have to have an idea on how much juice (technical term for electricity) you'll need for your other devices. Now you have to figure out how much juice you're going to put back into your battery each day. If you are only staying out one night you can do it when you return home. If you're out in the boondocks you can charge by connecting it to your tow vehicle and running the engine (maybe while toodling about), solar, generator, thermonuclear, or whatever. You shouldn't charge a battery at more than about 10% of its capacity so it's gonna take 3-5 hours to properly charge it back up.
A human body will put out about 100 watts when resting. So 3 amps at 12 volts is about a third of that.
These are all things that need to be considered to make it work. A lot of folks are "overly optimistic" about what and for how long they can run something on a battery.
Look before you leap.
Hope this helps.
Cheers,
Gus
