someone had actually tried it in a TD viewtopic.php?f=29&t=18104&hilit=rowerwet&start=15 , enjoy.
jstrubberg wrote:Rowerwet,
When you lower ambient air temp, you have to remove a LOT of water because the ability of the air to hold moisture is drastically reduced. If you don't get rid of the water, you end up cold and clammy instead of cold and comfortable.
Mloves2camp wrote:Would this small, 12v dehumidifier help with the humidity factor of the ice air conditioners, or swamp coolers when used in higher humidity areas? http://www.sunpentown.com/sdmide.html
I'm not sure just how fast it removes the 11.8 oz according to their specs, though. Is it safe to say that's in 24 hrs? On air conditioners, it gives it per hour, so I'm confused.
Anyway, Walmart shows this item for $48 & is ac/dc. Weighs only 5 lbs, so I'd consider using two if need be, doesn't take up much room, either. Looks like it could be mounted on a wall. http://www.sunpentown.com/sdmide.html
Now, I'll sit back & let the smart ones here decide if this would be helpful in our quest for cool, non-humid air! Thanks to those who know these things!
Marianne
Users browsing this forum: Google [Bot] and 8 guests
