What do you guys use for a hard wired battery charger? You know if you are using your 12 volt system all weekend, what do you use to keep the battery from dying?
Do you just use the big battery tender or something else?
Thanks!
225 wrote:My plan on 12 volt system is:
All LED lighting inside.
2 Dome lights, 2 reading lights.
2 hatch lights
car stereo
and fantastic fan
slowcowboy wrote:just charge the battery of your tow vehcile though the trailer wiring and the trailer plugs and run one wire from you tow vehciles postive post on the tow vechiles battery and to your teardrops battery.
and forget about a drop cord and a place to plug it in and all the high dollar solar panels.
just takes like 10 to 15 mintes of idle and charging time with your cars engine to recharge your teardrops battery and it uses next to no gas.
slow
GuitarPhotog wrote:I use a WFCO 8725 Converter/Charger. It provides 12VDC for lights and accessories, contains a smart charger for the battery, and handles 120VAC distribution with its circuit breaker panel.
Progressive Dynamics makes similar units that are made in USA, if that's important to you.
<Chas>
MDAcresDirector wrote:GuitarPhotog wrote:I use a WFCO 8725 Converter/Charger. It provides 12VDC for lights and accessories, contains a smart charger for the battery, and handles 120VAC distribution with its circuit breaker panel.
<Chas>
What is easiest way to hook this product up
225 wrote:What do you guys use for a hard wired battery charger? You know if you are using your 12 volt system all weekend, what do you use to keep the battery from dying?
Thanks!
