Generic Benroy Total Weight
Postby Pierre » Fri Mar 17, 2006 2:32 pm
Hi All
I am sure the answer is somewhere in the forums, but I have been searching and have not found it yet. Can anyone tell me the weight of a generic Benroy. I have a Honda Element with a towing capacity of 1500lbs...can the benroy be towed by this vehicle.
Thanks
" A silly question is one not asked"
Pierre
Postby SteveH » Fri Mar 17, 2006 2:38 pm
Pierre,
First, welcome to the forum. You've come to the right place if you are interested in building a teardrop.
To answer your question, it shouldn't be a problem. If you go by the plans, your trailer should be significantly less than 1500 pounds. My trailer is sort of styled like a Benroy, is 5' X 9", and built on the heavy side, and is about 1250 pounds. Pictures of the construction methods are in my gallery.
Again, welcome to the forum and madness! :?
SteveH
SteveH
Images: 42
Benroy Weight
Postby Pierre » Fri Mar 17, 2006 2:47 pm
Thanks for the help
Pierre :)
Pierre
Postby Spadinator » Fri Mar 17, 2006 2:59 pm
The estimated weight of my Generic Benroy is less that 700 lbs. I built light but I am also not finished yet.
Never do anything you don't want to explain to the paramedics.
Spadinator
Images: 47
Re: Generic Benroy Total Weight
Postby mikeschn » Fri Mar 17, 2006 3:05 pm
Hi Pierre,
Welcome to the forum....
We need someone to build the Generic Benroy so we know the exact weight. But to put it in the ballpark, my first Benroy was 4x8 and weighed 840#. My second benroy was 5x10 and weighed 1540#. You should be somewhere between those two numbers...
Seriously though, I think you'll be near the 1000# mark...
Pierre wrote:Hi All
Thanks
Generic Benroy . . . .
Postby rooster » Fri Mar 17, 2006 4:48 pm
My tear is a Benroy style at 1300 lbs. Does one put brakes on one that heavey? My tow vehicle is a 97 GMC Jimmy, V-6.
Jim, :?
Beware of what she wishes....especially with that twinkle in her eye and that mischievious smile....you know it's gonna cost....
rooster
Images: 42
Postby elmo » Sat Mar 18, 2006 7:36 am
SteveH,
Nice gallery. What is your tongue weight and how many inches from the back?
Thanks Elmer
It's scary when you start making the same noises as your coffee maker.
elmo
Images: 216
Postby SteveH » Sat Mar 18, 2006 9:19 am
Elmo,
The tongue weight is up there since I loaded the tongue box with all the junk I can fit in there...about 175 pounds, but my Dodge truck doesn't care. The axle is 39" from the rear, the body is 9' long, and 5' wide.
SteveH
SteveH
Images: 42
Re: Generic Benroy . . . .
Postby Mitheral » Sat Mar 18, 2006 5:05 pm
rooster wrote:My tear is a Benroy style at 1300 lbs. Does one put brakes on one that heavey? My tow vehicle is a 97 GMC Jimmy, V-6.
Jim, :?
Your close in most places (1500lb limit) for a trailer with no brakes. Add in 200lbs of food/ice and assorted gear and you're over.
Mitheral
Images: 19
Postby mikeschn » Sat Mar 18, 2006 5:17 pm
In light of the borderline weights, it sounds like trailer brakes are in order... that's a nice accessory by the way!!!
