Plywood Framing
Plywood Framing
Postby molethai » Sat Mar 18, 2006 3:35 am
I am new to the board, and so far it has been enlightening & entertaining.
I apologize if I missed this info in my scouring, But...
Has anyone looked into and/or tryed using plywood for framing?
It seems people use laminate lay-ups or metal for framing. I am particulary interested in the main curved pieces on the top of the sides. I hope my description makes sense. To my thinking it would be a lot easier to cut 3/4 ply than lay-up strips. I realize that you still need vertical supports, solid pieces would be best, I think.
as an aside, what is luan? I am guessing thin plywood.
I am hoping to begin building as soon as it thaws, in about 2 months I think.
Thanks. Mole
molethai
Postby Ira » Sat Mar 18, 2006 6:57 am
Yep, Mole--you missed it:
A lot of people DO use ply for the framing, but most especially at the top, like you're talkiing about, for those curves. For straight verticals, it's just easier for a lot of us to use 1 by 2s.
And yep--luan is just real thin stuff that bends nice.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby molethai » Sat Mar 18, 2006 7:47 am
Thanks Ira.
I will continue to look for info/plans/discussions
Mole
molethai
Postby SteveH » Sat Mar 18, 2006 9:14 am
Unless I totally missed the boat on this one, Luan is a type of Mahogany wood and is used making plywood.
SteveH
SteveH
Images: 42
Postby madjack » Sat Mar 18, 2006 9:35 am
Steve, at one time all Luan was mahogany. Now it is used to refer to any number of generic hardwood plys from 3rd world sources(ie Phillipine "mahogany")
madjack 8)
Postby SteveH » Sat Mar 18, 2006 11:13 am
Jack,
I just had to check it out...copied from Capital City Lumber web site:
Luan Plywood: A cheap grade of Mahogany plywood available in 1/8" and ¼" 4x8 pieces. Perfect for Cabinet backing, or any utility purpose.
So, now we all know...at least what Capital City calls it. :lol:
SteveH
SteveH
Images: 42
Re: Plywood Framing
Postby mikeschn » Sat Mar 18, 2006 11:20 am
molethai wrote:Has anyone looked into and/or tryed using plywood for framing?
Mole
I've started a plywood framed Widget...
The first thing I noticed is that it's very heavy.
Also since it's 1/32" smaller than the 3/4" insulation that I want to fit in there, I'm afraid I won't get a good bond between the framing and the skin.
That's about all I have to offer at this point in time...
Postby Chris C » Sat Mar 18, 2006 11:49 am
Mike,
THAT's the picture I wanted to show him. l think that is the better solution. No joints to have to try and match perfectly. As far as the plywood being thinner, I just plan to use a more efficient insulation, (in my opinion) the foil and bubble material. It's not rigid and shouldn't pose a problem with the difference in plywood thickness.
Chris :D
Chris C
Postby Nitetimes » Sat Mar 18, 2006 11:49 am
That's the way I did mine. I used 3/4" ply and removed everything I didn't need. I thought it was going to be heavy but after I got it all cut out I found it wasn't bad at all. It also makes things go a lot quicker.
I also came to the conclusion that with a little more planning I could have cut it down more and eliminated a little weight. But my plans kept changing as I built it so I wanted to make sure I had a bit of a fudge factor for my mount points.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby molethai » Sun Mar 19, 2006 12:18 pm
Thanks Mike!!
That is not what I had in my head, but a much better Idea. Weight is not a great concern. Ease of build & cost is.
Thanks all for the clarification on Luan.
Mole
molethai
Postby vooodooou » Mon Nov 20, 2006 10:40 pm
hi all
mike what kind of joint did you use on the widget to glue th plywood together and what kind of glue ? Thanks
vooodooou
Re: Plywood Framing
Postby halfdome, Danny » Mon Nov 20, 2006 11:20 pm
Mole
Very nice looking frame Mike. :thumbsup: If you want to regain that 1/32" you might look for regrind plam. Regrind is left over plastic laminate that the mfrs like Formica & Wilsonart regrind the good side of plam. Cabinet shops use it for backer sheets. It glues very well on both sides. :) On my tear the Popular lumber was 31/32" thick so I ran the pink foam down in my wide belt sander. That stuff melts easily as I would find almost pencil sized melted scraps at the end of a run. Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Classic Finn » Tue Nov 21, 2006 4:28 am
Mike that framing looks real sweet.... but then again you knew that... 8) 8) :thumbsup: :thumbsup:
Classic Finn :thumbsup:
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Jiminsav » Tue Nov 21, 2006 10:55 pm
well gee..y'all fawn over Mike's frame and he didn't even finish his..I finished mine. :D
Jim in Savannah
Jiminsav
Images: 40
Postby SteveH » Wed Nov 22, 2006 8:53 am
Jim,
I'll "fawn" over yours...whatever "fawn means, I don't know, but anyway, I really like the profile of your trailer, and the roofing material also.
Now, when are you gonna put fenders on it? :lol:
SteveH
SteveH
Images: 42
