Frameless?
Frameless?
Postby Evan Gaffney » Tue May 01, 2012 8:22 am
Okay, please don't throw anything at me. I tried the search function, honest! I'm sure this is one of those topics with equally strong arguments on either side, but I'd like to hear them.
Does a teardrop trailer really need a full steel frame?
It seems to me like the natural strength of a wood framed shell that has been glued and screwed throughout would be more than enough to support the relatively small weight of two passengers plus some gear. A lot of these build journals look like instructions for how to build a bomb shelter. I'm thinking maybe just a 2"x3" tube tongue that runs all the way back to the axle with a couple diagonal pieces of angle for support and one piece of angle at the leading edge of the floor to distribute the load. Something like this? (this would be a 5x10 floor plan)
Let's hear it!
Evan Gaffney
Images: 11
Re: Frameless?
Postby jstrubberg » Tue May 01, 2012 8:30 am
I think you're right, structurally.
I would go ahead and pay the small weight penalty and box the outside edge for two reasons. One, I tend to bump into stuff. I can use the extra protection. Two, I intend to mount a roof rack on my tear, so the outer wall becomes load bearing and I want that to transfer into a frame rail.
The more stuff I take along, the more time I spend taking care of my stuff!
jstrubberg
Re: Frameless?
Postby bobhenry » Tue May 01, 2012 8:45 am
The info is hiding in the design library....
http://www.angib.pwp.blueyonder.co.uk/teardrop/tear57.htm
Re: Frameless?
Postby jonw » Tue May 01, 2012 10:26 am
I didn't use a frame for my build and it's working out just fine. I used 3/4in. marine plywood for the floor which is waterproof and very structurally stiff and stable.
From my build journal here's a picture of the underside before the axle was attached (click to enlarge):
84804
jonw
Titanium Donating Member
Images: 163
Users browsing this forum: Bing [Bot] and 6 guests
