Emergency Road Side Coverage
Re: Emergency Road Side Coverage
Postby JuneBug » Thu Apr 05, 2012 2:59 pm
BrwBier wrote:It wont help in all situations but if you wheels are too tight here's what to do. Next time you are in for service request that the wheels are put back on with a hand torque wrench only. If they wont do it maybe you are going to the wrong place. Wheels are one of the more important items to be torqued properly. Its the only way its done at our shop.
Brwbier
Ditto!
"The large print giveth; the small print taketh away" Tom Waits
JuneBug
Postby Hndbskt » Tue May 01, 2012 10:10 pm
Good idea, any idea how much this adds to your annual AAA membership?
Maureenm wrote:Have you talked to AAA about +RV coverage? It doesn't add too much to ordinary plus coverage and your trailer is specifically covered. Some people are not aware that this is level of coverage you need to have your trailer attended to.
A fellow Teardropper told me about it and she works for AAA.
Hope this helps!
Maureen
Hndbskt
Postby Mukilteo » Tue May 01, 2012 10:20 pm
I pay $125.00 a year for "AAA Plus RV"
Eric
Mukilteo
Images: 18
Postby Hndbskt » Tue May 01, 2012 10:33 pm
Just renewed our annual Membership, we have a Plus service (with extra towing, living in Montana) for $125. I'll have to go ask about what it would be to add RV.
Mukilteo wrote:I pay $125.00 a year for "AAA Plus RV"
Hndbskt
Postby Shadow Catcher » Wed May 02, 2012 5:04 am
some will squawk but I use anti seize on lug nuts and a torque wrench set initially at 70 FP and second round at 80 FP. As with any tightening you do it cross wise so that tensioning is even then check tension/torque at 100miles after initial. A torque wrench at HF is a very useful tool and current price is $25.
I learned early on with a VW Bug that an even tensioning is very important or you distorted the brake drum.
Postby Hndbskt » Wed May 16, 2012 10:30 pm
AAA Plus RV is now AAA Premier, we are signing up, thanks for the tip.
http://www.aaamtw.com/membership/member ... ndbook.pdf
Hndbskt
Postby BrwBier » Thu May 17, 2012 5:45 am
Shadow Catcher wrote:some will squawk but I use anti seize on lug nuts and a torque wrench set initially at 70 FP and second round at 80 FP. As with any tightening you do it cross wise so that tensioning is even then check tension/torque at 100miles after initial. A torque wrench at HF is a very useful tool and current price is $25.
You know of course that torquing a bolt with anti seize on the threads is not accurate, right? It would also be nice if you would let everyone know when and where you will be traveling so we can be out of the way when a wheel flies off. Seriously though, putting anti seize on the threads is the dumbest thing that you could do. There is not a service manule any where that does not say "no oil on wheel threads". That is from 30 plus years as a mechanic.
Brwbier
BrwBier
Images: 100
Users browsing this forum: Bing [Bot] and 10 guests
