In your opinion. What is the Best paint for use on my camper, Latex or Oil based paint?
Also, in your opinion. What brand paint do you recommend?
Thanks,
Dave
Postal_Dave wrote:Since 2 out of 3 recommended Rustoleum, that's what I went with. The only problem is shaking all those spray cans.![]()
Just kidding. I used the rustoleum that comes in a paint can. However, this is thick paint. From trial and error, I can say this.
1) use a small amount of thinner so this paint lays down right. Two cap fulls per gallon might be a little too much, but that's what I used.
2) use a 1/4 inch nap roller. Don't use the standard 3/8ths inch nap, it's too thick.
Thanks for the recommendations guys.
Dave
absolutsnwbrdr wrote:I've had really good success using an exterior mildew resistant primer such as Kilz Premium (water-based), followed with Rustoleum High Performance Enamel (oil-based). Both are readily available, although the color selection of the Rustoleum is limited.
Users browsing this forum: Westy and 5 guests
