How to Splice 4 awg to a 12 awg
Anything electric, AC or DC
Postby Sevo » Wed May 16, 2012 8:16 pm
I am now in the process of wiring up my converter and can't find any splicers that would go from 4 awg to 12. I am tring to wire my amp and my battery. I have 4 AWG coming from the battery to the converter. The converter is 10 or 12 AWG. To my amp I also have 4 AWG and need to tie that into the converter as well. It to is a 10 or 12 AWG.
I was thinking of just getting a Gardner Bender HSB-28 Butt Splice Kit (http://www.amazon.com/Gardner-Bender-HS ... m_sbs_hi_1) The 4 AWG will fit perfectly but the 10 AWG will be very loose in that. Will this work?
Any ideas are greatly appreciated
Thanks
Chris
Chris L.
http://www.NAFEX.net
The North American Falconers Exchange
Sevo
Re: How to Splice 4 awg to a 12 awg
Postby RAYVILLIAN » Wed May 16, 2012 8:30 pm
Not very pretty but how about some ring connectors like you'd use to ground to a frame and a bolt to hold them together and tape it up. they make them with 1/4" holes for both sizes of wire.
gary
111961Image
RAYVILLIAN
Images: 109
Postby Shadow Catcher » Wed May 16, 2012 8:35 pm
Why not use a split bolt, not as neat but effective. a Tyco CPGI-GELWRAP-18/4-200UL will als. work and be a good bit more compact
Postby Sevo » Wed May 16, 2012 8:37 pm
Shadow Catcher wrote:Why not use a split bolt, not as neat but effective. a Tyco CPGI-GELWRAP-18/4-200UL will als. work and be a good bit more compact
Thank you for the fast reply...
I thought about using one of those. I was unsure if that would work?
I may give that a try
Chris L.
Sevo
Postby Lgboro » Wed May 16, 2012 8:48 pm
I just used a crimp sleeve on the same size wire a couple of hours ago. Will probably use liquid electrical tape on the connection tomorrow if
it not raining.
Lgboro
Images: 53
Postby Sevo » Thu May 17, 2012 6:51 am
Lgboro wrote:I just used a crimp sleeve on the same size wire a couple of hours ago. Will probably use liquid electrical tape on the connection tomorrow if
it not raining.
Where did you get the #4 crimp sleeve?
Chris L.
Sevo
Postby Lgboro » Thu May 17, 2012 12:54 pm
sLowe's here had a mixed pack with 1/4 and #4 here. Any welding supply or old timey hardware store probably has them too.
Lgboro
Images: 53
Postby H.A. » Thu May 17, 2012 1:07 pm
m
H.A.
Return to Electrical Secrets
