What recommendations do you have for 12VDC wall switches that could be mounted in a shallow box with a face plate?
Thanks for your help.
H.A. wrote:I use Carlon NEMA spec boxes and regular household duty switches.
bdosborn wrote:H.A. wrote:I use Carlon NEMA spec boxes and regular household duty switches.
That's fine for 120V circuits but a bad idea for 12V. You should always use 12V rated switches as its actually takes a more robust switch to interrupt a 12V arc than a 120V arc.
H.A. wrote:bdosborn wrote:I should have been more complete with my comment. But for brevity and not over-analise the subject.(what seems to be a requirement here)
zipz71 wrote:Dc rule of thumb here, about halfway down the page.
http://www.carlingtech.com/amp-hp-volts
bdosborn wrote:Try Del City, I've bought from them and there stuff is pretty good:
http://www.delcity.net/store/Switches/
