Rockhopper - Solutions!
Re: Rockhopper
Postby mikeschn » Sat May 26, 2012 3:21 pm
This is the last piece for today. This is the main rib. It attaches to the sidewall, behind the door. The inside wall butts up against it. The main spar that holds the hinge is also attached to this rib. I'll have more pictures of this main rib maybe tomorrow.
Re: Rockhopper
Postby RAYVILLIAN » Sat May 26, 2012 3:27 pm
Hey Mike I thought you were building a Weekender that looks more like the Escape hatch.
Gary
111961Image
RAYVILLIAN
Images: 109
Re: Rockhopper
Postby RAYVILLIAN » Sat May 26, 2012 3:41 pm
Mike Looks like you have the frame for a built on tongue box but don't show it in the profile drawing. Which way are you going to go attached or unattached. If you go attached don't put the door on the roof I'm still fighting leaks on that. ONly thing that I'd done different.
Gary
111961Image
RAYVILLIAN
Images: 109
Re: Rockhopper
Postby mikeschn » Sat May 26, 2012 4:54 pm
And here's how the pieces look, setting up along the fence!!!
Re: Rockhopper
Postby KCStudly » Sat May 26, 2012 6:31 pm
Very well thought out and detailed. Good progress, too. :thumbsup:
Re: Rockhopper
Postby mikeschn » Sat May 26, 2012 6:38 pm
RAYVILLIAN wrote:Mike Looks like you have the frame for a built on tongue box but don't show it in the profile drawing. Which way are you going to go attached or unattached. If you go attached don't put the door on the roof I'm still fighting leaks on that. ONly thing that I'd done different.
Gary
Hi Gary,
It's going to be an unattached box, similar to this: Image
Regarding the weekender, it was a toss up between that and the Escape Hatch. The Escape Hatch won! :BE :R :lol:
Re: Rockhopper
Postby RAYVILLIAN » Sun May 27, 2012 6:06 am
Having Built 2 I can understand why completely Mike. I'm still the biggest fan of this design.
GARY
111961Image
RAYVILLIAN
Images: 109
Re: Rockhopper
Postby stomperxj » Sun May 27, 2012 2:59 pm
Lookin forward to this build Mike - Did you get the reply email I sent with the DXF file?
Jess
stomperxj
Re: Rockhopper
Postby mikeschn » Sun May 27, 2012 4:54 pm
I didn't seem to make as much progress today. I got the subfloor done. It threatened rain halfway through, so I had to put everything away. But it didn't rain. So I dug everything out again.
Here's the subfloor.
Then I started on the plywood for the floor. I was just starting the angled cut for the front, and the rain drops started. So I put everything away again, and no more progress today. Hopefully we have fewer distractions tomorrow!
Re: Rockhopper
Postby mikeschn » Sun May 27, 2012 5:08 pm
stomperxj wrote:Lookin forward to this build Mike - Did you get the reply email I sent with the DXF file?
Jess
Yes I did Jess, thanks for sharing all those profiles! Lots of good ideas! Your Sawtooth was the best though! :D
Have you started designing number 2 yet? :thinking:
Re: Rockhopper
Postby High Desert » Mon May 28, 2012 10:21 am
mikeschn wrote:Here's the subfloor.
Sorry about the rain Mike, hope today is nicer.
So going with a flat floor on this one, no drop section?
Shaun
High Desert
Images: 27
Re: Rockhopper
Postby mikeschn » Mon May 28, 2012 4:30 pm
Yep Shaun,
No dropped floor on this one. The Hatch goes high enough that I don't need a one.
Anyways, got the floor on today... I had one bench from the last build, so I set it in place to see if the inside is tall enough. Seems to be. But I'll stick a mattress in there and double check.
Then we assembled a wall, and hung it in place to see how it looks...
I like it! How about you guys? (The fender needs a little bit of work yet.)
Re: Rockhopper
Postby RAYVILLIAN » Mon May 28, 2012 4:50 pm
It's looking good Mike. :applause: Keep it up and it could be campable by the 23rd. :twisted:
I think that the fenders look good with the off road look of the trailer.
Gary
111961Image
RAYVILLIAN
Images: 109
Re: Rockhopper
Postby jss06 » Mon May 28, 2012 11:10 pm
That is going to look really nice. Can't wait to see the finished product. :beer:
jss06
Palladium Donating Member
Re: Rockhopper
Postby High Desert » Mon May 28, 2012 11:20 pm
Agreed, looking good Mike. That style fender seems to "fit" nicely. :thumbsup:
Shaun
High Desert
Images: 27
