Aluminum Scratch Removal
Postby Javanino » Fri May 25, 2012 9:46 pm
I did a search but didn't find anything. I'm wondering what you guys suggest for removing scratches from .040 aluminum. I bought my skin from a truck supply shop. The 102" wide version. It was less than perfect from handling so I'm wondering what the best scratch removal method would be. Someone suggested 0000 steel wool and others have said very fine wet sandpaper.
Javanino
Re: Aluminum Scratch Removal
Postby Martiangod » Fri May 25, 2012 11:47 pm
start with 600 wet for light scratches, the move up to 1200 wet then 1600 wet and for mirror polish use baking flour with a terry towel
http://en.wikipedia.org/wiki/Sandpaper
3M Perfect-It Ultrafine Machine Polish and a rotary buffer with lots of clean towel, as soon as the towel starts to blacken, switch it up
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby Javanino » Mon May 28, 2012 9:23 am
Great info. Thanks!
Javanino
Postby RandyG » Tue May 29, 2012 1:03 am
RO sander with 180 the step it up to 1000 or 1500 by hand, the only way is to blend it out the buff it.
Randy
RandyG
Images: 115
Postby jonw » Tue May 29, 2012 6:36 am
Also, check out Nuvite polishes...
jonw
Titanium Donating Member
Images: 163
Postby BrwBier » Thu May 31, 2012 8:42 pm
Scratch removal on the aluminum that you have is a matter of what you want to end out with. I have the same product on my trailer. I tried to polish some spots on mine and soon discovered that I am not dedicated enough to "polish" my whole trailer. That said I will tell you why. I had a hard time getting the finish to look uniform. For me at least it was very hard to do. I soon became discouraged and looked for other ideas. That was when I found this site.
http://kirkhammotorsports.com/manual2/bodyfinishing/bodyfinishing.shtml
It is a lot of work but it looks good for years with very little work once you are done. It is also easy to fix minor scuffs and the like by just doing more of what you did in the first place. Getting the grain to be straight has a learning curve to it but can be done. It is way easier than doing a car like in the instructions on the web site. Just use the products mentioned on the site as a guide line, dollar store window cleaner works great on the aluminum. Any way FWIW, that how I did mine and I think it looks pretty good.
Brwbier
BrwBier
Images: 100
