Miriam C. wrote:Ira Dear
First be calm. Second get out your box and a good sharp back or box saw.
Third- If you have a 2" wide trim
on you 12 in Mark the 12 inch on only one side plus leave the width of your trim + 1" (you will cut this off with the miter) on the end. (both ends should be longer than 12" plus more than the width of the trim.)
Put the marked side against the inside of your box. At the 45 degree slot.
Be absolutly sure you have two short sides and two long sides.
Got that. Saw! Your miter box should have slices on both ends so use both ends and you will get it right.
Use practice wood and check your kerfing. (width of wood the saw removes)
DestinDave wrote:Wait till you graduate to crown molding Ira.. Those you cut upside down and backwards...
Rainjer wrote:
If you have a 12" opening, & want a 1/4" reveal, your material cut length wold be:
12" + 1/4" + 1/4" + 3" + 3"+ 18 1/2". I would rougn cut to 19".
Should read 12" + 1/4 + 1/4 + 3 +3 = 18 1/2 inches.
Its that shift thing with the + and =.
