what a week! finally had a couple hours tonight to get started
Day 5 - finished layout electrical in my mind & on paper & picked up last couple parts for that
Installed a temporary LED setup in the upper middle of the trailer as I'm not sure how bright they're going to be
16' total, double backed on itself to make 2 x 8' strips
Then finally decided how I want the electrical to be:
I'll run all electrical to the fuse box & have the 2 batteries, battery charger and inverter in it's own box.
Then have short cables to plug that box into the fuse panel when I go! No winter stuff to worry about...
It's gonna be a heavy box though as the batteries are ~80lbs each!
Went with some 5/8" plywood I had left over & a large number of brackets. all wood is glued together. That's the bottom you're looking at
One of the batteries is, um, helping that corner to stay put until the glue dries
I'll cut holes for handles & ventilation on the short sides
update as it's dark out finally!
Perfect amount of light I think - and they are on a dimmer, as will all the rest of the lights
