It's been a while since I posted so I guess I need to catch up. Getting a lot done, but not a lot of picture changes to show for it. Rain and humidity for the past two weeks have really slowed down my body work and painting. I've gotten four coats of CPES on all the outside and the first round of Fill-it filler, but I'm waiting on the weather to clear before I sand everything and do the fiberglassing on all the edges. While I wait on the weather, I've started on my electrical. My original plan was to install the battery in the storage area under the galley counters, but I decided that I didn't want to deal with a vent system so I installed a battery box on the tongue (I needed the tongue weight up there anyway). I'm running the battery cables through the cabin with a combination of wiremold and clear plastic tubing for conduit. On the other side of the cabin I'm running the trailer lights with the same type of wiremold and plastic tubing. The nice thing about the tubing is that it slides down inside the ends of the wiremold and protects the wiring. I've been buying a lot of parts online including coolers, cabin lights, hurricane hinge, bussbars, and terminal strips. They are all starting to come in now. Hopefully the weather will clear up soon and I can finish the filler, apply the fiberglass tape, and paint with Valspar tractor paint. One thing I should point out is that I cut my holes for my Fantastic fan and tail lights after I applied the CPES. I had a little CPES left over so I plan to go back and seal all those raw edges with several coats.
Battery box installed on tongue. I'll use clear plastic tubing as conduit to run the trailer light wiring and the battery wiring into the cabin. A slightly undersized hole through the plywood makes the soft plastic tubing seal really tight. I'm hoping it is waterproof without having to caulk. You can't tell by the pic, but the box is mounted really solid on a wood frame bolted to the spare tire rack with a full length metal strap washer inside. The size 24 battery is actually smaller than the size 27 box so there is plenty of room for the wiring and plastic tube conduit to run inside the box. I plan to fabricate a metal locking strap to hold down the lid and secure the entire box.
![Image](https://www.tnttt.com/gallery/image.php?album_id=2417&image_id=92052)
Wiremold on left side will carry battery cables to power cabinet. Similar wiremold on right side will carry trailer lights to galley storage area (rear side markers and tail lights). Haven't run wiring yet. Note receptacle installed in cabinet shelf for TV and heater.
![Image](https://www.tnttt.com/gallery/image.php?album_id=2417&image_id=92053)
Switch at top is the master battery cutoff. Figured that would work better than a big old knife switch hidden down in a cabinet. The hot battery lead will run through the switch and will remain off when not in use. All of my cabin lights have built in on/off switches so this will prevent something from accidentally draining the battery. Receptacles under the galley cabinets are also in wiremold surface mount boxes.
![Image](https://www.tnttt.com/gallery/image.php?album_id=2417&image_id=92054)
Backside of electrical cabinet. Progressive 4045 converter/charger will mount from the galley side and all AC/DC distribution will be inside this cabinet with access from the cabin. Note back side of cabin receptacle and battery cutoff switch installed.
![Image](https://www.tnttt.com/gallery/image.php?album_id=2417&image_id=92056)
Tail lights dry fit under tailgate area. Wanted to use LED's, but the old style lights were the only ones that fit flush and allowed the tailgate to drop down flat. (obviously a lot of sanding yet to do).
![Image](https://www.tnttt.com/gallery/image.php?album_id=2417&image_id=92055)
Found these Coleman coolers on sale at Sears online and they fit perfectly under the galley counter tops. I have two more coolers with handles and the camp stove to store in this area.
![Image](https://www.tnttt.com/gallery/image.php?album_id=2417&image_id=92057)
Hurricane hinge came in the mail today and will be ready to install when I finally finish the paint. The folks at Vintek are really great to deal with. I've bought a lot of major parts from them and shipping is always fast.
![Image](https://www.tnttt.com/gallery/image.php?album_id=2417&image_id=92058)
Hoping for good weather so I can get back on the body work. Stay tuned.
