slowcowboy wrote:I would its a thing called money and in the recesson now in america its a endangered item and in short supply and once its used up
its nearly impossible to replace. its not like you can go down the street and get a job and do any thing about it. till some politicans are removed from office and thats a long shot waiting to happen.
so.
can you fill a coleman power chill el cheapo 12 volt cooler with ice?
and not get water on the 12 volt componets and ruin stuff with a mini electrical fire?
and thanks will for the information that was a lot of what I am hunting for.
basicly I am after a way to make ice last a lot longer
kinda the genreal idea.
but if the fridges do get cheaper some way down to where a guy would not need to sale a hole cow to own one. I might conseder that option.
slow
pmowers wrote:Slow,
Like they said above, the thermoelectric coolers can only drop the temp about 35-40 degrees. There is a fan inside that blows the air over the cooled fins, filling it with ice will short everything out. The instructions all say not to put ice or liquid loose inside. They work pretty good if you "prime the pump" by putting a layer of frozen water bottles inside. If it isn't frozen or cold when it goes in, the cooler is not going to be able to get it cold. My 40 quart igloo draws 5-6 amps, all of the time since they do not have a thermostat in them.
I have started using a small icemaker when we camp. It is about the size of a large bread maker and puts out about 35 pounds of ice a day. The one I bought was about $100 and runs on 110 VAC drawing about 150 watts, not too bad on an inverter. Running it for an hour gave me about a gallon ziplock bag of ice-which I kept in the coleman, I just keep adding water and emptying the basket. The coleman 12V cooler was able to keep the ice frozen without a problem when the days were in the upper 80s, nights in the 50s.
slowcowboy wrote:hmmm so no termostate how much does your battery keep up?
do you run it with the car on and re- charging all the time or do you just draw on a battery alone with no re=charging going on as you use it.
the frozen water bottles gave me a idea.
and then there is programmable 12 volt timers.
slowjust pondering folks.
linuxmanxxx wrote:I have ac in my camper and just keep the cooler in there and it status as cold as fridge then. I'm sure the ice packs would keep things a lot colder longer but then the issue is where do you replenish the ice from?
StandUpGuy wrote:I bought one off of Craiglist. Not the colman cooler but another brand. I think they are all basically the same. They do work but it is relative the the temperature outside.- of the cooler. If it is 70 degrees outside the cooler will get down to about 45 degrees at best. You can put ice in it to start and after the ice melts you can continue to keep things somewhat cool. But if it is 90 degrees outside the cooler will not get any cooler than say 60 degrees. My cooler is an armrest console that resides between the front seats of my minivan. I plug it into the cigarette lighter and on a long trip it keeps drinks somewhat cold but it takes a very long time to cool down. Do not expect to put warm cans of soda into it and have them cooled down. Better to have already cold things. Its actually kind of a handy thing to have in the van.
BrwBier wrote:StandUpGuy wrote:I bought one off of Craiglist. Not the colman cooler but another brand. I think they are all basically the same. They do work but it is relative the the temperature outside.- of the cooler. If it is 70 degrees outside the cooler will get down to about 45 degrees at best. You can put ice in it to start and after the ice melts you can continue to keep things somewhat cool. But if it is 90 degrees outside the cooler will not get any cooler than say 60 degrees. My cooler is an armrest console that resides between the front seats of my minivan. I plug it into the cigarette lighter and on a long trip it keeps drinks somewhat cold but it takes a very long time to cool down. Do not expect to put warm cans of soda into it and have them cooled down. Better to have already cold things. Its actually kind of a handy thing to have in the van.
if it is 70 out side the cooler will get down to the 30s, if yours does not then it is broken. I have had one for about 10 years and when it is in the 60s I prop the cover open to prevent freezing.
Brwbier
